The Real Maverick
Jack
  • Thread starter
  • Banned
  • #1
XLT HYBRID
2100 miles unloaded: 77 mph cruise control 99% interstates.
Mountain West, High Desert, Prairie Grassland.
Starting Elevation: 50 ft. ASL
Max Elevation: 7500 ft. ASL
Ending Elevation: 450 ft ASL
Low temp 27°F High Temp 80°F.
30 hours. 10% gentle heater use. 5% gentle air conditioner use.
The rest, natural ventilation only.
230 pound self. 50 pounds "stuff". 87 Octane gas only.
Slight tailwind.
Net: 33.2 MPG
Reverse trip: Same roads.
Very similar conditions.
Slight headwind.
Lowered cruise control to 72 MPH due to head wind and added weight of vehicle.
230 pound self.
50 pounds "stuff".
1250 pounds cargo.
Truck Scale: 5180 with me inside and half a tank of fuel.
Net: 31.5 MPG
Ford Maverick Maverick Hybrid: Fully Loaded Headlamp Adjustment IMG_9689
OF WORTHY NOTE:
I mostly drove in daylight.
But had pre-arranged hotel to reach. The first time I drove after dark, I quickly realized my "projector" headlamps were pointing at the sky. One hour from first hotel I dealt with it. At hotel, got out the manual, and found it is:
REALLY FAST AND EASY TO ADJUST YOUR HEADLAMP BEAM HEIGHT.
I wish all Mother Truckers would do this. A full 20% of drivers on the roads have "projector" beams pointed too high.
I had to rotate the screw EIGHT FULL REVOLUTIONS which I think was all the way down. The screw got stiff and I didn't want to force it any more. Was near perfect like this.
Side note, after 1.5 year of ownership I fully believe mine were misaligned from the factory. For 1.5 year I have believed my "high beams" didn't do anything. Because they didn't. Turns out I was driving with "high beams" all the time.
This is my first vehicle with projector lamps. So I thought that's just how they were. What a wonderful difference now. Now I don't get blinded by reflector signs. It took a heavy load for me to notice this important FACTORY MIS ALIGNMENT issue.
UPDATE:
After unloading, I then turned the screws 4 revolutions back UP.
THIS SEEMS ABOUT RIGHT.
AND WHAT A DIFFERENCE!
For the first time in 1.5 years my low and high beams work as they should.
First Sergeant
Fruitland Idaho
Page: 320-321 of 2022 manual:
TAKES ONLY 1 MINUTE PER SIDE!
SO PLEASE PLEASE PLEASE DO THIS!
Phillips or a 6-point star adjuster? Looks like a six point.
Edit: I meant to say a hex (Allen wrench). The stars are the Torx type, sorry.
First Sergeant
Fruitland Idaho
Well, heck! As they say in the NFL, "After further review" looks like a hex on the top portion, then down below that looks like a Phillips? Maybe us either one, not sure.
MaveRichard
Rich
MI
2023 Ford Maverick XLT Hybrid
Sounds like you had an uneventful trip. Glad to hear it and great summary of the details.
I am curious if you experienced or noted any differences in temps (thinking coolant and MG1) between the TO and FROM trips?
The Real Maverick
The Real Maverick
Jack
  • Thread starter
  • Banned
  • #9
No difference.
Truck was not working that hard. Even on mountain grades.
HP made cruising empty: 25-35.
HP made cruising fully loaded: 40-45.
No where close to even half power output. This thing was "peppy" even while loaded in tow/haul mode.
Used slippery on down grades.
With wind resistance at highway speeds regen in tow is too great. Could not coast down hills. Also, no reason not to have EV mode on down grades. Gave the engine a little rest. Did about a 20 mile EV segment downhill. Engine water temp dropped to 130°F.
Flyin Ryan
Ryan
FLORIDA
2025 Hybrid Awd 4k tow Lariat Desert Sand color
XLT HYBRID
Slight tailwind.
Net: 33.2 MPG
Slight headwind.
230 pound self.
50 pounds "stuff".
1250 pounds cargo.
Net: 31.5 MPG
OF WORTHY NOTE:
My first vehicle with projector lamps. So I thought that's just how they were. What a wonder difference now. Now I don't get blinded by reflector signs. It took a heavy load for me to notice this important FACTORY MIS ALIGNMENT issue.
Full log daaayyyyaaaaaaaaammmmm great information tho 💯
MaveRichard
Rich
MI
Montana
I'm so glad they made the headlight adjustments simple.
I've had multiple vehicles that have just been a PITA to make adjustments on. Either some specific right angle tool was needed and a guesstimate of which direction is the correct way or just some cheap plastic thing that will strip if you look at it incorrectly :ROFLMAO:
Thanks for sharing that!
  • Like
Reactions: Dad
SKurj
Martyn
Kawartha Lakes, Ontario
18 mx-5, 23 XL eco AWD
oops this is an XL ecob
My trip last week, an extra 100lbs in the box for the trip home. Most of the mileage on interstates likely averaging 75mph. Kawartha Lakes Ontario Canada to Daytona beach and back.
Just realized the clock runs on this trip even when the truck isn't moving.
Ford Maverick Maverick Hybrid: Fully Loaded Headlamp Adjustment PXL_20240221_215910034
First Sergeant
Fruitland Idaho
It's phillips.
Just went out to shop and checked it. We can use either one. It is also a 6mm hex (Allen wrench) Nice to have options!
inline_five
2023 Hybrid XLT
I think this is a great example of engine choice based on area of operation.
Ecoboosts get like low 30‘s on the highway, similar to hybrids. There is very little difference at least.
But in the city the hybrid is a great choice.
Good post.
