- First Name
- Matt
- Dec 19, 2021
- Abilene Tx
- 94 Silverado , 07 mustang, 69 barracuda
- Engine
- 2.0L EcoBoost
- Banned
- #76
LED bed lighting strips. Took me about 2 hours. Mostly because I had to figure out how I wanted to route all the wiring, plus pulling the access panel and spare tire underneath for access. But seriously, A novice can tackle this. It's not terribly tough. Really, the hard part is running the wires.
This is Part 1 of the bed light install. You will need a 10mm socket, 7mm socket, a torx socket, scissors, zip ties, shrink tubing, clear silicone, some good double sided tape, masking tape, and a complete length wire hanger shaped straight with a hook bent on one end for fishing wires through.
The space I used for the strips measures 46". As such I cut them down to fit. Theres cut lines on the light strips. Remove the plastic end caps, Cut them at the cut lines at the desired length. Then glue the end cap back on with a little clear silicone. After that feel free to plug them together, and test them. The wiring is red to red, and black to yellow. Yellow in this kit is the (black) ground return.
Remove the RH cubby box if equipped. This requires removal of the lower cleat to remove the box. Remove the LH cubby box, or flat cover if equipped. Use the wire hanger to fish it through the upper bed hole to the small square hole behind the taillight. This will allow you to fish the wire through.
