Maverick accessories, mods, how-to's on my Maverick
OleKennyRoy
Kenny
Maverick Lariat
I have put anti seize on lug studs for over 35 years of doing mechanics. Never ever had an issue. I dont use a torque wrench on lug nuts either. I tighten them by hand with a breaker bar. Again never had an issue.
Using the German torque method (Good-und-tight), or snug plus a little, you you roll the dice on how much tension is on the wheel stud and thereby the axial (clamping) force on the wheel. The good news is there seems to be a pretty big range which is acceptable. If you calculate the force based on a Bronco Sport with a torque value of 135 Nm and 12 mm stud, you get about 56,250 N of axial force, and with the Maverick's 200 Nm and 14 mm stud the value is about 71,430 N.
Someone with a "feel" for how tight things should be may never have an issue, but Little Suzie or Johnny DIYer may find themselves chasing a wheel down the interstate if they're lucky, or in the ER if not. Most folks prefer to be safe than sorry, or at least eliminate risk when sensible.
There is a value provided by the manufacturer to ensure the proper axial force, or at least acceptable without breaking wheel studs, but to keep it consistent, you need eliminate variables like lubrication on the studs. The torque value (200 Nm) is based on clean, dry threads. If you put anti-seize or any other lube, the value needs to be adjusted, and the rule of thumb would be to reduce the torque 20-25%, but that may or not be correct based on the coefficient of friction of the lubricant used.
While your method works for you, and you have provided quality content to the forums no doubt, I believe it is important that other members are aware of the risks of applying anti-seize when installing lug-nuts.
Barracuda340
Barracuda340
Abilene Tx
One of the things I changed about the bed net was the climbers rings that were used. These are definitely much better.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221127_153420
Barracuda340
Barracuda340
Abilene Tx
Duly noted. Heres a P.S.A. NO anti seize on lug threads Johnny or Suzie D.I.Y.er, however in my 38 years of doing this stuff, I have never had a lug nut loosen up or a wheel fall off. You also need to remember the point of a conical seat on a lug nut and wheel is meant so that they dont loosen up under vibration. Its meant to wedge them together and apply additional side loading on the threads to keep them together. Cars dont come with torque wrenches in their tire changing kits. You are way overthinking this.
Barracuda340
Barracuda340
Abilene Tx
Catch can brackets are done, sandblasted, primered. And painted. Did the 10mm Shelby Dodge bolts in a Krylon silver that was almost a spot on match for the OEM silver. Got it all bolted up. Will get to the plumbing part of it soon. Probably this weekend. Second set is for the wifes future XL.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221129_120147
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221129_154406
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221130_181942
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221130_201552
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221130_201606
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221130_203113
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221130_203121
Dad
I've had that experience while sitting passenger in a friend's 90's era Bronco . . . watching one of his wheels passing us by while on the freeway. Truly terrifying. Luckily, no wreckage or serious damage.
Maverick Grabber
Indiana
2015 Chrysler 200, 2022 Maverick XLT Red
This thread is meant to chronicle the accessories I purchased for my Maverick, as well as the prices for each item, and ease of assembly or install. Also any items I may have fabricated. I am doing this because theres some folks on the forum who are not very mechanically inclined. The aim is to also show that a lot of this stuff is not very hard to do even for those who are not mechanically inclined.
Myself, I am a mechanic, and have been fixing, modifying, and fabricating things since my teens. I am 54. I am in the aviation industry as a sheetmetal structural repair technician, and also teach sheetmetal repair. I want to make each post geared towards the novice on the truck club who is not very mechanically inclined. For those of you who are mechanical you will probably appreciate the prices and where I got each item, or the method of fabrication. Theres lots to come. I have had this truck only 2 days.
I used to live by Seattle, someone NOT ME LOL had stolen some titanium from Boeing and tried to sell it to a scrap yard, the owner tells him he has to call and find out how much it was worth, he called the cops lmao
Maverick Grabber
Indiana
Custom wheels or alloy wheels in general. I have had water get between rims and brake rotors and damn near corrode these parts together to where you cannot remove the wheel from the vehicle. I am installing custom wheels, however anybody installing aluminum wheels should do this.
Brush anti seize compound on the lug studs, and on the rotor mating flanges so if moisture gets between the rim flange and the rotor, you can still get them apart. My aftermarket rims use aluminum hubcentric rings. I buttered these up with permatex antiseize as well. Truck needs a 3" lowering job now to ditch the 4x4 look.
Rims are Circuit performance CP30 18x8.5 with a 35mm offset. Tires are 245-55R18. Same outer diameter as stock.
anti-seize works for galvanized plumbing threads too under the tape
Barracuda340
Barracuda340
Abilene Tx
My Eibach drop springs arrived yesterday. It's going to be awhile before I install these. The crewchief opposite shift of me in the department we both run has not taken any of his vacation. So he has 4 weeks of it. Dont use it, you lose it. Company wont cut you a check for it. As such, he is gone until the new year, and I am working all my days, and all my days off except for Christmas day, and some select vacation days that i have left, sucky part is the end of december is when our really cold part of the year starts. That lasts thru March. These will likely sit in their box in the corner of my shop until springtime.
In all honesty I am glad this marathon work schedule dropped in my lap. I could use the money. Last month I decided up upgrade the old Lionel trains under the Christmas tree that my wife hated because of the noise to a starter set of LGB G scale trains. Then she wanted a new tree, so money on that, and the Eibach springs. Then a week later the washing machine quits. I'm pretty good at resurrecting this stuff, but the clutch inside the auger is shot. Its frozen together, cannot get it apart. No time to mess with it. Time for a new machine. This overtime is going to help pay for all this, and get me ahead a little bit.
As such, there probably not going to be much to report on with my truck for a bit. Maybe a few small things. I got RokBloks coming. Black with grey logos. I'm not normally a logo whore kind of guy, but I will give it a shot. If I'm not ok with the logos, i can always color em in with a fresh new black sharpie lol.
I may also take off these seat covers. I'm not feeling it honestly. I may end up doing what I did with my 94 Chevy to keep it fresh looking for 28 years. That was to buy an extra large bath towel and drape it over the front seat and tuck it in for my on shift days. Maybe I can find one for the silver buffalo that kind of matches the seat color. If I remove the covers, I may keep them for road trips, or post them on here for sale.
I am also looking at doing the removable mid panel thing with the 2x6 or 2x8 with a twist. I may make mine out of welded thin wall steel tubing and expanded steel, then paint it black. Kind of on the fence about it. Building it over and over in my head. This will end up being less weight actually than a carpeted 2x8.
Barracuda340
Barracuda340
Abilene Tx
Valve cover oil seperator plumbed. I have a few things I need to do to complete it all, but for now this is how it is. I did add hose clamps after pic was taken.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221203_191436
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221203_191444
Barracuda340
Barracuda340
Abilene Tx
I finally painted and installed my custom tailgate tiedown I made to go with the tailgate assist strut today, and got my radio knob trim piece. It fits really good, but theres some light grey that's visible. Before I install that piece for good I think I will color those visible spots in with a black sharpie marker
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_192229
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_192238
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_192903
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_192839
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_192932
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_191921
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221206_191942
Dad
Having that tie down is a must for the Maverick's limited bed.
Barracuda340
Barracuda340
Abilene Tx
RokBlokz $149 I think they were. Easiest mudflap install I ever did. 20 minutes tops. Never even had to take the wheels off. Stubby phillips screwdriver, 10mm socket, right angle phillips screwdriver, and a bubble level.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221207_190351
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221207_190408
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221207_190444
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221207_190427
Don806
Don
SE Ohio
Those look great
Barracuda340
Barracuda340
Abilene Tx
We have been getting a lot of rain in west Texas, and these RokBlokz are doing their job well. Not a lot of dirt flinging up on the side of the body. I definitely recommend.
The newest little thing I did was make a clip to hold my 3D print front trash can more secure by pulling it up against the console. It's a piece of .020" stainless steel I dug out of the scrap bin at work. I will glue it to the trash can with super glue. It holds it pretty nice and secure not glued though.
First pic you can see the trash can doesnt fit up tight against the console. With the clip, It will still lift out easily for cleaning it out. I may trim the top of the trash can lip at the back down a little bit to make it even with the console edge, and then install the clip. This will give me a little more room to access the console lid latch, plus I never let the trash get that high anyways lol.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221211_180108
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221211_180117
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20221211_180135
mikeakasully
Wisconsin USA
2010 Ford Escape, 2023 Ford Maverick 2.0 Ecoboost
About 6 months ago I made up 2 pairs of bed tracks. I used logistics track. Surface mount undrilled. I drilled and countersunk these, and made end caps from .040" stainless steel. The stainless steel metric hardware is from www.belmetric.com . the tracks are from www.cargocontrolcorp.com . Cost in materials and tiedowns I got off evilbay I think I spent maybe $60 in materials.
Very cool. I'll definitely will be doing this to my truck when it comes. Better than Ford's $400 option.
https://www.cargoequipmentcorp.com/...systems/custitem_cec_facet_categories/L~Track
