Manufactured obsolescence
Frenchy6784
Jean-Louis
Galt, CA
2025 Maverick lariat
Had that happen to my grandson's Jeep, Bad gas cap seal $11 on Amazon. Some part dealers like auto zone will check the code with an OBDII scanner for free hopping to sell you parts.
L30n1d45
Nebraska
2025 Ford Maverick 2.5L Hybrid AWD
Less than two years old and just a hair over my stellar warranty and I get this beauty, Sweet!
It is a check engine light. You're still new enough and low enough miles to be within the powertrain warranty. Take it into the dealership and have them check the codes, it might still be covered.
tuneturner
New Jersey
2024 Ford Maverick Tremor
Some and I emphasize some emission parts are covered and some are not under your factory emissions warranty (5yr/50k). Since you are just out of warranty you may want to call Ford Customer Service hotline and open a case - they will give you a case number. Better to have this first before going to the dealer - some won’t lift a finger to help especially if you did not buy it from them. If you have bought Fords in the past and have a service and maintenance history with Ford you have a very good chance of it being covered under Ford’s goodwill policy. Having the code read is helpful but sometimes does not pinpoint the exact issue as you may need the PIDS from Ford’s IDS. Hope this helps and good luck.
dochawk
doc
Las Vegas
It would be kind of self defeating for them not to be able to scan for you!
I drove around for months with one in the car, connected, in the F-150. I could reset it with three taps on the same button without even looking down, and get a handle on how often it was misfiring that way!
Marty
2026 Ford Maverick Tremor
That's why I didn't buy a hybrid :crackup: . Didn't want to learn a new type of propulsion.
I didn't buy the Mavbrid because I know me. I'd never be able to leave that Orange cable alone.
I have been hit by lightening three times in my life.
Potatomafia
Eastern New Mexico
2023 Ford Maverick XLT Hybrid
I dunno, I think I'd rather get a CEL and have some modicum of an idea of what it could be rather than have weird stuff happen (dash was dead, transmission stuck in park, random weirdness with the ACM; all fixed by a restart) or strange noises/vibrations randomly popup then disappear.
Marty
there are a lot of simple, cheap things that can cause the CEL.
I had it thrown for a $5 PCV valve.
I like it when the CEL says, O2 sensor bad.
So you change it out, $124.00
Then
It says catalytic converter bad.
So you change it out, $1800.00
Then
It says, O2 censor bad.
So you change out the second 02 sensor.
Then
It says, the EGR is bad.
and you set fire to the car, watch it burn.
Then you realize it was just a light and you could have put electrical tape over it.
:’P
