manual passenger seat won't recline
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
tried to recline the passenger seat in my xlt lux this morning and found that the seat back would go back or forward. not a giant issue as i usually don't have passengers in the truck but it's another thing to have fixed at the next service. anyone else have this issue? search function didn't reveal anything...
jsus
2022 Ford Escape Hybrid AWD
Just to state the obvious, on the side of the passenger seat, there should be one lever to adjust height up/down and one to adjust recline. Forward/back is of course controlled by the bar under the front of the seat.
Stimpy433
Chad
Iowa
2022 Mavrick
Yeah, make sure you’re pulling the right lever, my wife was trying to get the seat back to recline and was pulling the wrong lever
  • Like
Reactions: wjg
Brian_J
Brian_J
Akron, Ohio
I'm pulling the correct lever.
fishinmagician
2022 maverick hybrid XL
Which lever are you pulling? Also maybe try putting some tension on the seat when you pull the lever, the gears might be jammed up a little
Brian_J
Brian_J
Akron, Ohio
I'm pulling the lever that adjusts the seatback angle. I tried pulling and pushing on the seatback while pulling on the seatback adjustment lever.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi Brian, I'd be happy to look into your Maverick seat concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Brian_J
Brian_J
Akron, Ohio
Done! Thanks!
Dave_in_PA
Eastern PA
2017 F-150
Did you get this fixed, mine has the same issue.
Brian_J
Brian_J
Akron, Ohio
Brian_J
Brian_J
Akron, Ohio
Iirc, they replaced the seat back.
I’m having the same problem. What did you do to resolve?
Read the 2 posts right before yours.
Good use of search function!
