Back Seat Won't Raise
Thanks for the suggestions. I tried that and everything else......maybe I should get a fat gal in the backseat?
Will probably end up taking it to the dealer.
Might ask the fat gal to get off the back seat and then pull the strap? 🥰
WAIT! Are you pulling the seat belt strap?
unlimited
Heidi
Missouri
F-150 Limited
You could just ask the Fat Gal to fix it since you aren't capable. :ROFLMAO::ROFLMAO:
Trucklet
D
2022 Ford Maverick XL AWD 4k
If there was a place all of us who ordered a 2022 Maverick could go and collectively have a beer together, we need to make that happen.
I would absolutely die laughing if we all went out for a beer only for the bartender to tell us that they're out of beer. We hang around griping just long enough to see a random guy walk in and get a pint straight away.
JennyJoannSuebeeMcNash
Jenny
East Coast Florida
2016 Ford F150 XLT
The bartender would take one look at ALL of us and say, "We don't serve your kind here."
AvianQuest
AvianQuest
Ralph
Conroe, Texas
So the recall only deals with towing trailers with brakes which I won't be doing. I don't want to pay $200-300 for a rental while getting the back seat fixed, but I would need a vehicle to take the wife to physical therapy and such.
RR - All the way
GA
You probably should take out the fat gal in the backseat before you go to the dealer. Technicians might get sidetracked!!;)
Looney1
Larry
Georgetown, Texas
Did they fix it?
No they didn’t but I did. I went to my scheduled appointment but when I got there he said I would have to leave my truck because the trim people were backed up. Typical. So I brought it back home and was able to fix it in about 10 minutes. Open your back passenger door and at the bottom of the seat you will see a small panel. In the center of the panel is a round plug cover - remove this with a thin bladed common screwdriver, then remove the screw (Torx). Pull the panel out enough to get to the trip lever. Pull it and raise the seat and then remove the other screw on the bottom of the panel. Remove the panel and you will see a cable with a pin on the end. Reattach the pin into the lever - it will only go in one way. Reinstall the panel. It literally took me less time than writing this. Good luck!
AvianQuest
AvianQuest
Ralph
Conroe, Texas
Thanks to Milous for sending me a PDF of the shop manual pertaining to removing the rear seat.....like 64 pages of it.
Thank you Looney1.
Hoagus
Sacramento, CA
‘02 Ranger, ‘22 Mav XL
Thanks for the detailed write up.
AvianQuest
AvianQuest
Ralph
Conroe, Texas
So today I stopped at the Ford dealer again and asked if I could chat with the trim tech for a couple of minutes to see if they had encountered this problem. I was told "No", but they did send out an employee who owned a Maverick. He said the only situation he had hear of was the seat locking in the raised position.
He did say that since I've got a Case Number that Ford should furnish us with a rental. Anyone know about this?
RR - All the way
GA
I doubt that if you get a 500 lb. fat gal in the back seat that you will get the seat or anything else to rise.... :unsure: ;)
inthecabin
Andy
2021 Ranger Lariat FX4
Maybe let a few homeless guys in it for a “soup kitchen” that might loosen it up..
