Maintenance Logbook for Mav hybrid
inline_five
2023 Hybrid XLT
Hello,
Does anyone have an easy to edit logbook of sorts to use? This is my first new car, and first time I'll be a stickler for the factory schedule.
My Toyota had one that was every 10k miles IIRC, and included what you had to do each 10k.
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
oysterville
Oregon
2024 Maverick Lariat
Pencil and paper aren't easy enough?
Montana
I just write things down but don't actually do them 🤣
Also, inb4 some idiots start spamming this thread with "lifetime fluids" advice.
OP, I have tons of info on my build log in my sig. Page 2 has tons of part numbers (Most are for the EB, so ignore stuff like my choice on oil).
inline_five
2023 Hybrid XLT
Did you actually find a log book to record the MX performed?
I have just been recording mine on a spiral note pad.
No I'm making one from that section. It's poorly laid out (the Ford manual). Once done I can post for critique etc.
Oscarcat
Eric
Encinitas California
It's one thing to know when a service is due. It is another, and less convenient, to know when you actually did the last service.
To that end of knowing when I did something, I write something like "O+F 9/3/24 5,256 mi. using a black Sharpie on a 1-1/2" strip of blue painters tape and put it on the door jamb. No hunting or guessing.
X tires 9/3/24 5,256 mi. Eng Air 9/3/24 5,256 mi, Cabin air, R&R Coolant, X-ATF etc. and so on.
I've got one in Excel - I'll send tonight when on computer, and if memory serves me.
That's a tough combo though. (let's see, where's that bookmark and reminder function...)
I've got the frequent checks laid out, the higher mileage items, ect.
ETA: My sheet is specific to the hybrid, I also included mileage/time references for some items sooner as based on Car Care Nut discussion about hybrid Toyotas you plan to keep, not just the manufacturer making it past the warranty limits.
The 24MY manual basically has no schedule, nothing but the references to a few normal checks.
The online was active, you clicked on each mileage 10k interval, and it listed the items done then. Which is what I went thru building the spreadsheet. Which I printed for easy access to check off items.
Here's the 24MY manual comments on maintenance, nothing else but going online.
Scheduled Maintenance Service Intervals
For your scheduled maintenance service intervals, visit https://www.ford.com/support/maintenance-schedule.
Owner Checks and Services
Make sure you perform the following basic maintenance checks and inspections every month or at six-month intervals.
Check Every Month
Engine oil level.
Function of all interior and exterior lights.
Tires, including spare, for wear and proper pressure.
Windshield washer fluid level.
Check Every Six Months
Battery connections. Clean if necessary.
Body and door drain holes for obstructions. Clean if necessary.
Cooling system fluid level and coolant strength.
Door weatherstrips for wear. Lubricate if necessary.
Hinges, latches and outside locks for proper operation. Lubricate if necessary.
Parking brake for proper operation.
Seatbelts and seat latches for wear and function.
Safety warning lamps (brake, ABS, airbag and seatbelt) for operation.
Washer spray and wiper operation. Clean or replace blades as necessary.
Multi-Point Inspection
In order to keep your vehicle running right, it is important to have the systems on your vehicle checked regularly. This can help identify potential issues and prevent major problems. We recommend having the following multi-point inspection performed at every scheduled maintenance interval to help make sure your vehicle keeps running great.
ďż˝
Accessory drive belt(s) Hazard warning system operation
Battery performance Horn operation
Engine air filter Radiator, cooler, heater and air conditioning hoses
Exhaust system Suspension components for leaks or damage
Exterior lamps operation Steering and linkage
Fluid levels1; fill if necessary Tires, including spare, for wear and proper pressure2
For oil and fluid leaks Windshield for cracks, chips or pits
Half-shaft dust boots Washer spray and wiper operation
May not be what you want but I log my maintenance/service details in FordPass. Quick access anytime anywhere and Ford or Dealer can see proof/details if there’s ever a issue, question etc
allc0re
Ryan
2024 Hybrid Maverick XLT
Anyone know where all the door and body drain holes are?
inline_five
2023 Hybrid XLT
I've been wondering as well.
After washing or driving through heavy rain, the next day I will pull the door seals on the bottom to drain the water that is held in them. It's particularly bad in the rear.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Yep!
I have used a note pad for every truck I have ever owned.. :cool:
Jerry
