CurtisB
2023 Maverick XLT Hybrid
So, these lights have three wires going to them, assuming they are ground, turn signal on and headlight on. The passenger side has a connector that goes to the park/turn bulb and another to the headlight (driver side goes only to the park/turn). What was the point of adding the second connector on the passenger side and then also the single red wire going across to the driver side? Why not just use the single connector on both sides and use the park lamp signal to trigger the animation and keep lights on instead of headlight? Would make the connections so much cleaner.
Edit: I guess the only benefit is if DRL are on, these side markers should also come on. The light animation activates via the red wire. When doors are unlocked, the parking lights activate first, followed by the turn signals. If connected to parking lights, the animation will activate for a brief moment, before the turn signals override it. If connected to the headlights, it activates only when the headlights are switched on, so I don’t see much of an improvement. Opening the doors via remote, you will never see the animation, since the headlights never switch on (unless they do on upper trims).
The way the harness works it allows the side markers to turn on at dusk when the headlights turn on. I didn't notice this until I was parked next to a car.
Nemo
24 Maverick XL
Right, and connecting to the parking lights will do the same, as they come on with the headlights.
Dave O
New Smyrna Beach Florida
I want these Side Marker Lights lit when I’m flat towing my Maverick and connected to my RV to add extra lighting so my Toad is more visible at night - when I’m towing as you would guess my tail lights are luminated and the brake lights work but headlights are always off
Mr Pibb
Vegas
2024 Lariat
You'll definitely need to sand down the passenger side one, mine was catching until I did. Its not noticeable that its shaved down for the door to clear.
CurtisB
Some of the people who posted pictures of how far off the passenger side is really is bad. Mine needed just a little sanding.
Ford Maverick Mabett | Upgraded Side Marker Lights Available Now! 20250323_154108
Ford Maverick Mabett | Upgraded Side Marker Lights Available Now! 20250323_154116
uga
SE USA
2026 Ford Maverick XLT
Interesting how the original version did not have this issue but had water issues instead.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
🤓 I got mine back in 2022 when they first came out, and I never had water issues.
Becker300
Robert
Eden Prairie
2023 Maverick XLT - Alto Blue
Thanks. Getting ready to install. BTW, where did you get the XLT badge?
uga
SE USA
Correct, if you were one of the first to purchase the original version there were no issues. But after that initial run they were a leaky mess. Its to bad, I really liked the original version.
CurtisB
Amazon. Problem is you have to buy the entire alphabet. You do get 2 of each letter and it does come with numbers. It was around $10.
Becker300
Robert
Eden Prairie
Thanks. Appreciatethe response.
MABETT
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
Williyjoe
Cincinnati
2025 Maverick XLT
Hey everyone,
We’re excited to share some great news – Mabett Side Marker Lights are now in stock and ready to transform your Maverick!
What’s New?
âś… Enhanced Waterproofing: Waterproofing has been upgraded for more reliable performance.
✅Plug-and-Play Installation: Effortless setup with no complicated wiring – just install and go!
✅Personalize Your Look: The silver part in the middle can be DIY-painted to match your Maverick’s unique style – make it truly yours!
Buy directly via the link below, 20% discount exclusive for MTC.
👉 Shop Now on Amazon: https://www.amazon.com/promocode/A20ST5HRF64621
Note: If the product shows as "out of stock," it simply means it’s in transit to another Amazon warehouse, but you can still place your order without any issues.
Upgrade your ride today and experience the perfect blend of style, functionality, and reliability.
Thank you for your continued support, and we can’t wait to see how these lights enhance your ride!
🌟Join our community to stay updated with the latest product releases, exclusive promotion discounts and abundant opportunities for free product trials.
I have not been able to find the new version of the marker lights. Can you tell when and where they will available?
MABETT
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
The new version will be available in about one month.
Brueggy
2024 Maverick Lariat
I just received the Mabett side marker lights. These are the 3rd generation just released May 28 on Amazon. The install was pretty straightforward. One thing of note was that when I removed the old badge, the clips that held it in place remained in place. I did not realize that the new badges included clips installed on them. Trying to force the new badge/lights with clips into the existing holes containing the old clips did not quite work. Left a huge gap and unsecure installation. Just a stupid mistake when trying to rush the job. Even with having to redo my first attempt, it only took about 20 minutes.
Ford Maverick Mabett | Upgraded Side Marker Lights Available Now! IMG_3240
Ford Maverick Mabett | Upgraded Side Marker Lights Available Now! IMG_3241
Ford Maverick Mabett | Upgraded Side Marker Lights Available Now! IMG_3238
Ford Maverick Mabett | Upgraded Side Marker Lights Available Now! IMG_3239
