I wired my truck up a while ago but not like most people did. I also added the DD foglight kit and wired it all in. I will attach a copy of my wiring diagram but not sure if you will be able to follow it. My foglight orange backlight and Mabett side markers are always on when the truck is on. The side markers flash with my turn signals. I can turn my foglights on whenever I want them on as long as my parking lights are on, high or low beam or headllights off makes on difference. The DD optional stuff (red boxes) on diagram was only put on as options that DD recommended....I did not follow them. I have an Ecoboost Lariat. I also installed switchback turn signal bulbs and wired them up so that they are always on (white) while the truck is running (just like my led under hood strip) and they flash orange when the turn signal is used. I do not think I put them on this diargram however.How did you wire your driver and driver harnesses to obtain this please?
This may be more complex than you want since there is a lot of stuff in this diagram.
My power for the Mabetts comes from a fuse tap I added to the engine bay fuse box. I can't remember which fuse I used....found it on forums and tested it...but it is a line that only had power when the truck was running(accessory line). No chance of killing the battery. If you follow my approach try something like fuse 3 (horn) and see if power is killed once the truck is off and setting. Use an add on fuse to that circuit if it drops power when the truck is off and sitting for 30 seconds. I only needed a 10 amp add on fuse for everything and even that is probably more than twice what I really needed for all those led lamps.
