Longevity, or First thing TO-DO when received new Maverick!
BLZ57
Brent
Anacortes, WA
2023 Maverick on order; 2016 Shelby GT=H
You have put a lot of thought into the longevity of your Maverick, so it would seem you may keep the truck for a long time. Good!
I would get a back-up OEM PCM/ECM (computer brain) from a MY22 with your configuration from a wrecked one. CarParts.com is a good source.
I had a 95 Windstar that we bought new. Car manufactures only need to supply replacement parts for 10 years. It was not too long after 10 years that the PCM failed. So this may have been around 2010, or a bit earlier.
This was a nightmare. Ford no longer stocked. Re-flashed PCM's were not cheap, and neither was the labor. And did not come with a warranty from standard auto parts suppliers. Ran OK for a while and failed again. Put another one in, ran, but not as good as before. That one failed. Put a used OEM one from EBAY (not a California car) and it ran ok, but not as good as before.
About 15 years later, I was talking to the parts mgr at my Ford dealership - he had the same experience on a different FORD model (Escort I think) - had to junk the car.
I have a 2016 Shelby that will stay in the family forever. Last thing I want is it not to at least run as it did from the factory.
Ford made a zillion Windstar's, less 2016 Mustang GT's, and well, not many Mavericks. I picked up a couple of OEM PCM's with low mileage from wrecked cars - each about $200 - cheap insurance that the car will run correctly in the future. The Windstar PCM was on the interior side of the firewall (labor intensive). The 2016 Mustang in under the hood, in the engine bay, right next to the exhaust manifold. All the heat and electronics makes me nervous. I don't know where the Maverick PCM is located yet.
I will get one from a wrecked MY23 AWD that has my configuration. Chances are it will never fail, but it becomes a nightmare when your car won't run.
Sorry for the long reply, you got more than just my 2 cents...
mavmav
mavmav
Walter
New York
Maverick Hybrid 2022
Im new to cars, and have a few questions
1. Can you provide a guide to where all ground terminals are that you sprayed?
2. Curious why you mixed differenr oil weights? this concept is new to me
3. what oil filter did you use for your first change?
1. on hybrid, right under the hood all terminals that are screwed to the body and one under back seat (battery minus terminal wire)
2. I always mix oil with porsche cayenne for last 16 years. For Maverick hybrid. in winter i do mix 5:1 ration and in summer i would do 2:5. 5w30 is 1.7 times more viscous than 0w20. Be careful. By mixing i try to reach not existing 1w22-2w24. mixing oil is very tricky and you really have to consider: a)engine starting and operating temperature, b) high temperature limit. c) RPM and load. i am not concern about MPG consumption. i may lose one percent of MPG and that's totally fine with me.
Oil test results will tell you all details. I am very confident with 5:1 mix in NY area. if i live in hot climate i would no doubt mix 2:5 ratio. if you are not familiar with oil properties, stay to manufacturer suggested 0w20. I am sure I'll get criticized for mixing oil :D
3. filter. i am using oversized wixxp, good oil filters are PurolatorONE, AMSOIL etc. look at micron rating. that is very important if you are concern about engine longevity. PurolatorONE is very cheap and has 99% at 20 microns and goes down to 5 microns with i think 50-80% effectiveness.
Kwanzaa
No
2.0 Ecoboost XLT Maverick
Thanks for all the answers. very appreciated
scotty
pompano berach fl
dodge caravan
BTW. transmission oil change procedure
i will use AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL)
if you want to use ford oem oil: Motorcraft® MERCON® ULV Automatic Transmission Fluid
XT-12-QULV WSS-M2C949-A, MERCON® ULV
Start the engine and allow to run for 1 minute. Turn engine off and wait 5 minutes.
Check the transmission fluid level.
The transmission fluid should be even with the bottom of the transmission fluid leveling plug hole.
Install the transmission fluid leveling plug.
Torque: 26 lb.ft (35 Nm)
thank you.
srfdude44
california
kia optima
Torque: 26 lb.ft
JonP_Maine
Jon
Veazie Maine
2025 Ford Maverick XL
Sounds good. I live in Maine and have debated adding an oil catch pan. Still on the fence given how cold it can get here in winter. I burn non-ethanol gas; always something rated "Top Tier" Yes, it is more expensive but I don't drive nearly as much as I did before I retired so I'm OK with it. Having an Ecoboost with a turbo, I am most cocerned with nastiness building up in the engine. Did my first oil change 3 months in and went full synthetic. Truck only has 2300 miles (Bought last October)
Also did rustproofing out of the gate (Krown) and used Mabett kits to cover up some of the gaps in the underbody as well as adding mud flaps. Also added a Weathertech hood shield. I have had these on 2 previous trucks and have had them both prevent damage from stones flying up on the highway. Bonus-they look really nice. Also a Mabett kit to cover gaps on the bumper near the tow connection. Weathertech floor mats since it gets so nasty on the ground in Winter - just wash them off.
Strong recommendation for snow tires in winter. I went with Blizzaks and they performed wonderfully this past winter. The AWD was fantastic. I mounted them on the steel wheels that came with the XL and went with a nice set of street wheels for Summer that were mounted with the original Continentals that I will replace with something else when they wear out.
Added bonus, I have the 4K Tow package. Even when not towing, the truck performs a little better given what is included (Higher capacity radiator, better cooling fan, transmission cooler etc.)
Overall, I great little truck and I was surprised how capable in winter given how it is structured vs. a traditional pickup.
Suzukiridr14
Frank
Sarasota Florida
I received my 2.5 Hybrid. I plan to keep my Maverick for 10+ years. first thing I have done to prolong longevity of my Mav:
  1. I changed my first oil at 200 miles - glad I did. it was full of metal sparking particles. Main reason why i change is that I don't like the fact that ford is putting small oil filter and semi-synthetic oil blend vs. full synthetic oil and full size filter. After initial oil change sequential oil change will be done every 5-6k miles or 100 hours of engine operation. (oil used: Pennzoil Platinum 0-w20 with one 3/4 quarter of 5-w30 Engine works more smoother and much quitter) Cost $35. time 30 min.
  2. Oil Undercoating, I drive upstate NY and PA. there are tons of salt on the road in winter that will contribute to metal corrosion in just a few years. i chose to do B'LASTER SURFACE SHIELD Rust Protectant and 3M Cavity Wax Plus Aerosol Spray, 08852 with 3M Cavity Wax Plus Applicator Wand Kit. 3M worked very well in enclosed tube and frames where Surface Shield is good for underbody undercoating like crossmember and rocker panels. I didn't use fluid film brand in my case that is also very good option. Cost: 3M with Wang kit $60 and six cans of BlLASTER SURFACE SHIELD $60 (used four out of six) total $120. time 2 hours
  3. Sprayed with anticorrosion oil all ground terminals to prevent premature oxidation and corrosion. Bad ground may cause unwanted error codes. cost $2. time 10 min.
  4. Oil Catch Can. Since this is hybrid engine that starts and stops often, I added Oil Catch can to prevent carbon buildup on engine valves. cost $35, time 1 hour.
  5. I will change all liquids in summer when i reach 15-20k. coolant, brake fluid, differential and transmission oil. After initial change i will be changing liquid again after 80k or 3 years. cost assumption $ 150 time assumption 3 hours.
I am not mentioning mod that i have added: cruise control, lighting etc. this thread about longevity. Please add items you think that may add longevity to ford Maverick. Thank you in advance!
Since you are planning on keeping your Maverick for many years, I suggest you get an ESP from Granger before the cost goes up every 6 months. It's better to have it, and not need it, then need it, and not have it. In the furture, 1 visit for a needed repair, will pass the $1K just for labor.
