Longevity of the OEM Michelins.........
NJBob
New Jersey
Interesting tidbit: The Ford OEM Michelin Primacys are made to specific Ford-OEM specs. Their tread depth is 8.5mm verse the exact same non-Ford spec tire is like 11mm. This is a common ploy by OEMs to mount name brand tires on new vehciles but save $$$ as they buy in bulk...deeper tread costs more.
Yes starter tires. Find this practice abhorrent.
Deral
Deral
Bellevue MI
2023 Ford Maverick
That's the same thing Sears did with their store brand appliances. Get brand name companies to make products using Sears standards.
JP4AZ
Phoenix
It's kind of like when you buy an new printer and it comes with a "Starter" Toner Cartridge. It will only print 100-150 pages. Then you have to buy a real Toner Cartridge.
I have around 4/32" with 20k miles on my OEM Michelin Primacy. I haven't noticed traction problems or hydroplaning in the rain yet, but I'm a little concerned about winter performance.
The first edition ecoboost I originally had used a 235/65-17 Falken Wildpeak AT3W, same tire that's on the Tremor. That's a 29" tall tire compared to 28.6ish for the 225/60-18 or 225/65-17. I am probably going with a 255/55-18 on my stock 18s next, and I hope I don't need to install spacers. A safer play is a 245/55-18 instead.
JP4AZ
Phoenix
Colin,
You should be just fine. I have 265/60/18 on mine, completely stock suspension, no rubbing at all.
Ford Maverick Longevity of the OEM Michelins......... 20230628_143704_resized
Colin,
that's a big 'ol tire! nice.
I'm going to install eibach lowering springs, literally have them here at my desk just waiting for a cooler day. but the eibach proof-of-concept Maverick used a 29" tall 255 also, I think it was a 20" wheel. I'm pretty confident in the 255/55-18, but there is some variation in tire models of the same size.
vinnymac
Vince
For those that have had their Mavericks, if you have the OEM Michelin Primacy tires, how many miles are you looking at them lasting. I would like to replace them with at tire with a little more off road tread, but want to wear these out first. Interested in your thoughts........
40 k with on time rotations at 5k I do maint every 5k
Found these at discount close to stock but heavier and 75k tread wear
FALKENSINCERA SN250 A/SP 225 /60 R18 100H SL BSW
Item #26775
BETTER
$155.00 + Installation costs added in cart
Treadwear720
TractionA
TemperatureA
SECTION WIDTH 225
ASPECT RATIO 60
RIM DIAMETER 18"
OVERALL DIAMETER 28.74"
RIM WIDTH RANGE 6.0" - 8.0"
WEIGHT 29 LBS
TREAD DEPTH 11"
LOAD INDEX 100
LOAD RANGE SL
MAX PSI 51 PSI
SPEED RATING UP TO 130 MPH
SIDEWALL DESC. BLACK SIDE WALL
WARRANTY 75000
VPN 28291826
GTIN 848983005885
YazYaz
Northeast
2019 Ford Escape
These tires offer a great ride. Smooth and quiet. They will last to 40K.
LSchicago
Lloyd
IL
Colin,
Really like the look of these on your truck. Being that my truck is a hybrid I may use 235/65/18's instead for a little less rolling resistance while getting the tall sidewall. Your tires remove much of that wheel well gap, while potentially raising the rear a bit in case it gets rear ended. It may help against a total.
JP4AZ
Phoenix
Lloyd,
Thank you for your comment.
I have this set up planned for my Hybrid. Wheels are from Mustang Mach E (a little larger offset).
And of course the best tire on the Market!
Ford Maverick Longevity of the OEM Michelins......... 20230106_140108_resized
It's a good looking wheel, and I have no problem with that center cap. If an electric wagon can identify as a Mustang, so can your Maverick. :LOL:
JP4AZ
Phoenix
LSchicago
Lloyd
IL
Maverick, Bronco, Mustang at least they can all be horses.
