Jmav216 how the heck did you those crossclimate2 to fit? I want them on my '23 Mav Hybrid Lariat that came stock with Michelin A/S 225 60R 18 100H but when I try and lookup the CrossClimate2 it says not compatible?
Fitting is one thing "compatible to OEM SPECS" is another. For instance on Michelin's web site Primacy 225/60/R18 100H FOR BSW, Primacy 225/60/R18 100H TOY BSW, & Primacy 225/60/R18 104H FOR BSW (FOR = FORD OEM SPECS & TOY = TOYOTA OEM SPECS). THE AFTERMARKET Primacy (NOT on compatible list?) has more tread depth, most likely different compound, and weighs 2lbs heavier is warranted for 55k miles vs the Ford OEM at 45k miles! Also it appears that a 104H load range FOR OEM was made and could be ordered or possibly available at Ford Dealer if you want heavier load range and still have a FORD APPROVED tire??? for which vehicle??? Bottom line there is a VERY Fine Line between compatible and not compatible. Different Rolling resistance may also come into play.
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
Has anyone tried 235/65/18 on stock suspension?
NoVaJimmy
NoVa
2019 Lexus GX 460
Yes, @NoVaJimmy is running that size. I could only find one picture of this size, I tried asking for more but never got a reply. Seems to fit stock suspension without issue though.
https://www.mavericktruckclub.com/f...-r18-work-for-the-maverick.25036/#post-469807
Unfortunately I'm currently running a different set of wheels with even larger 245/70R17 tires on them (so unable to take photos of that setup installed) and no rub at all (Stock suspension). Where the issue comes from is people who run wider aftermarket wheels with a similar offset, this brings the inside lip of the wheel and the tire closer to the strut and wheel liner. You should have no issues at all with the 235/65R18 tires on stock wheels (7" width and a 37.5 offset).
Ford Maverick List of larger aftermarket All-Terrain tires sizes that will fit the Ford Maverick MavWBSBLWheels
DinoLord
Brandon
Conroe, Tejas
24 XL EB AWD
I believe these are the largest tire you can fit without any suspension modification: 265/60/18.
Tire is: Hankook Dynapro ATM Wheel is: 18x8 with 40et. They ride very nice with no rubbing.
How much clearance on inside?
That's exactly the setup I want to run, but my wheels are 18x8.5 +42
JP4AZ
Phoenix
I have since traded it in on a Cyber Orange Hybrid, so I can't tell you how much. I can say that even at full lock no rubbing. the closest spot to rub was the pinch welds about mid tread (I had mudflaps on the AWD and that covered the pinch weld) which added to the lack of clearance.
Ford Maverick List of larger aftermarket All-Terrain tires sizes that will fit the Ford Maverick 20230915_142405_resized
