Limp Mode Fail Strikes Again!
Dad
Yea the way the limp mode kicks in concerns me greatly. With Ford being mute on this issue figured I might as well contribute something constructive to the conversation seeing as how I have a somewhat vested interest. I'm just lucky in that I've never had this happen in traffic or at any kind of speed, unlike some other members here. But because of this, my wife is scared to drive the truck in case it pops on her and she would rather tempt fate in her old Mini Cooper that needs to go into the shop every other month for some new mechanical defect.
Completely understandable. I wonder if there are any legal options to be pursued to get Ford's attention. Very troubling.
Oscarcat
Eric
Encinitas California
Well, this has now happened to me three times in a row, and quite honestly I wish Ford would give us something solid to go off of, especially for those of us who don't have the luxury of dropping off the truck for an extended period of time at a Ford dealer.
So, the symptoms - start driving, and the truck suddenly throws a barrage of errors - ESC fails, gear selection at low speed message, hill assist disable, pre-collision assist disabled, ABS light is on, MIL is on, service wrench is on, and drive mode selection is disabled. Might be something else in there that's disabled, but you get the gist. Truck loses all response to gas pedal, slows down and then slams on the parking brake at like 1-2 mph. Taking the parking brake off, you have no gas pedal input and the truck just accelerates up to 30-35 mph (don't know the exact number, because every time this has happened to be the speed limit was 30 or less so I ended up just riding the brakes to keep the speed down).
The only benefit here, and why I'm also making this post, is to share that there is a bit of a workaround so you're not completely stranded in a garbage situation. And we'll get to that here in a minute.
At least with the fail this time I had my laptop with me, so fired up FORScan and managed to get a complete system read of all the failures in real time. So here's the fail right after it happened (luckily I was in a parking lot, so was able to pull immediately over into some open spots):
First capture at 20240405 1518z
Code:
===SOBDMC DTC U1011:86-AF===
Code: U1011 - Invalid Internal Control Module Monitoring Data Received from ECM/PCM
Additional Fault Symptom (:86):
- Signal Invalid
Status (-AF):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Secondary OBD Control Module C
Freeze Frame  #1:
-EVENT_TIME: 42662823 s (Fri Apr 05 16:15:17 2024) - Event time
-TOTAL_DISTANCE: 15946 miles - Total Distance
-MODULE_VOLTAGE: 15.0 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 66 °F - Outside temperature
-ENG_TQ: 0.4 ft·lb - Engine Torque
-PRNDL_T: N  - Shift Position
-TFT: 70 °F - Transmission Fluid Temperature
-M_SPEED: 752 1/min - Motor Speed
-GTQ_CMD: 0.0 ft·lb - Generator Torque Command
-MTQ_CMD: 0.0 ft·lb - Motor Torque Command
-M_INV_V: 222.90 V - Motor Inverter Voltage
-G_PHTMP: 70 °F - Generator Inverter Phase Temperature
-MCLTEMP: 79 °F - Motor Coil Temperature
-GCLTEMP: 81 °F - Generator Coil Temperature
-G_SPEED: -749 1/min - Generator Speed
-TQ_DSD: 0.0 ft·lb - Desired Total Torque
-M_PHTMP: 86 °F - Motor Inverter Phase Temperature
-VEHMODE: Driving  - Vehicle Control Mode
-ECU_ONTIME: 64 min - Module On Time since Key On or Reset
-ECT: 115 °F - Engine coolant temperature
-CTO: 0 1/min - Tachometer signal output
-HV_AMP: 1.60 A - High Voltage Battery Current
-HVBAT_V: 222.50 V - High Voltage Battery Voltage
-APP: 9.00 % - Accelerator Pedal Position
-VPWR: 14.64 V - Control Module Voltage
-VS: 6.1 mph - Vehicle Speed
===END SOBDMC DTC U1011:86-AF===
===SOBDMC DTC U1028:00-26===
Code: U1028 - ABS Control Module Received Invalid Data from ECM/PCM 'A'
Status (-26):
- Malfunction Indicator Lamp is Off for this DTC
===END SOBDMC DTC U1028:00-26===
===BECM DTC None===
Successful DTC reading, no error codes found
Module: Battery Energy Control Module
===END BECM DTC None===
===PCM DTC U1010:00-AF===
Code: U1010 - Invalid Internal Control Module Monitoring Data Received from Hybrid Powertrain Control Module
Status (-AF):
Module: Powertrain Control Module
Freeze Frame  #1:
Freeze Frame  #2:
-EVENT_TIME: 42662822 s (Fri Apr 05 16:15:16 2024) - Event time
-FUELSYS: error  - Fuel System Status (Open/Closed Loop)
-LOAD: 0.00 % - Calculated Load Value
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: -3.91 % - Long term fuel trim 1
-MAP: 14.5 psi - Manifold absolute pressure sensor
-RPM: 0 1/min - Engine Revolutions Per Minute
-VSS: 6.2 mph - Vehicle Speed
-SPARKADV: 0.00 ° - Spark Advance
-IAT: 68 °F - Intake Air Temperature
-RUNTM: 104 s - Time Since Engine Start
-EVAP_PCT: 0.00 % - Commanded Evaporative Purge
-BARO: 14.5 psi - Barometric pressure
-VPWR: 14.89 V - Control Module Voltage
-TP_REL: 7.84 % - Relative Throttle Position
-TAC_PCT: 9.41 % - Commanded Throttle Actuator Control
-EVAP_VP: 1.7 psi - Evaporative System Vapor Pressure
===END PCM DTC U1010:00-AF===
===OBDII DTC U1011-P===
Status (-50):
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII DTC U1011-P===
===PACM DTC None===
Module: Pedestrian Alert Control Module
===END PACM DTC None===
===DCDC DTC None===
Module: DC to DC Converter Control Module
===END DCDC DTC None===
===BdyCM DTC B1444:15-08===
Code: B1444 - Left Rear Stop/Position Lamp Output
Additional Fault Symptom (:15):
- Circuit Short To Battery Or Open
Status (-08):
- Previously Set DTC - Not Present at Time of Request
Module: Body Control Module
===END BdyCM DTC B1444:15-08===
===BdyCM DTC B1448:15-08===
Code: B1448 - Right Rear Stop/Position Lamp Output
Status (-08):
===END BdyCM DTC B1448:15-08===
===BECMB DTC None===
Module: Battery Energy Control Module B
===END BECMB DTC None===
===BCM_C DTC None===
Module: Body Control Module C
===END BCM_C DTC None===
===TRM DTC None===
Module: Trailer Module
===END TRM DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===ABS DTC U0401:00-2F===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status (-2F):
Module: Antilock braking system
Freeze Frame  #1:
-MODULE_VOLTAGE: 14.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 64 °F - Outside temperature
===END ABS DTC U0401:00-2F===
===ABS DTC U0131:00-2E===
Code: U0131 - Lost Communication With Power Steering Control Module 'A'
Status (-2E):
Freeze Frame  #1:
===END ABS DTC U0131:00-2E===
===TCU DTC None===
Module: Telematic Control Unit Module
===END TCU DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===GSM DTC None===
Module: Gear Shift Module
===END GSM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===ACM DTC U0255:00-28===
Code: U0255 - Lost Communication With Front Display Interface Module
Status (-28):
Module: Audio Control Module
Freeze Frame  #1:
-EVENT_TIME: 42567147 s (Thu Apr 04 13:40:41 2024) - Event time
-TOTAL_DISTANCE: 15883 miles - Total Distance
-ELEC_POE_STAS: Not Received  - Electric Power Status
-ING_STAS: Run  - Ignition Status
-POW_TOR_STAS: Powerpack Start In Progress Torque NA  - Powerpack Torque Status
===END ACM DTC U0255:00-28===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===IPMA DTC U0418:86-AF===
Code: U0418 - Invalid Data Received from Brake System Control Module 'A'
- Signal Invalid
Status (-AF):
Module: Image Processing Module A
Freeze Frame  #1:
-EVENT_TIME: 42662822 s (Fri Apr 05 16:15:17 2024) - Event time
-VEHICLE_SPEED: 6 mph - Vehicle Speed
-ECU_POWER_SUPPLY: 14.7 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 93 °F - ECU Internal Temperature
===END IPMA DTC U0418:86-AF===
Well, that sucks, especially with 15 miles of 60 mph country road ahead of me. But, still have a couple of errands to run, so let's just reset the codes and see if it comes back. And what do you know, still in limp mode, complete with all of the systems disabled messages. Second read from 20240405 1521z:
Code:
- Signal Invalid
Status (-AF):
Freeze Frame  #1:
-EVENT_TIME: 42663153 s (Fri Apr 05 16:20:47 2024) - Event time
-OUTDOOR_TEMPERATURE: 68 °F - Outside temperature
-ENG_TQ: 0.0 ft·lb - Engine Torque
-PRNDL_T: P  - Shift Position
-M_SPEED: 0 1/min - Motor Speed
-M_INV_V: 221.90 V - Motor Inverter Voltage
-G_PHTMP: 73 °F - Generator Inverter Phase Temperature
-MCLTEMP: 77 °F - Motor Coil Temperature
-GCLTEMP: 79 °F - Generator Coil Temperature
-G_SPEED: 0 1/min - Generator Speed
-M_PHTMP: 77 °F - Motor Inverter Phase Temperature
-ECT: 108 °F - Engine coolant temperature
-HV_AMP: 1.20 A - High Voltage Battery Current
-HVBAT_V: 221.50 V - High Voltage Battery Voltage
-APP: 0.00 % - Accelerator Pedal Position
-VPWR: 14.72 V - Control Module Voltage
-VS: 0.0 mph - Vehicle Speed
===SOBDMC DTC U1028:00-AE===
Status (-AE):
Freeze Frame  #1:
-EVENT_TIME: 42663164 s (Fri Apr 05 16:20:58 2024) - Event time
-MODULE_VOLTAGE: 13.0 V - Control Module Voltage
-M_INV_V: 48.70 V - Motor Inverter Voltage
-VEHMODE: Powerup  - Vehicle Control Mode
-CTO: -32768 1/min - Tachometer signal output
-HV_AMP: 0.00 A - High Voltage Battery Current
-HVBAT_V: 222.00 V - High Voltage Battery Voltage
-VPWR: 12.64 V - Control Module Voltage
-VS: -203.6 mph - Vehicle Speed
===END SOBDMC DTC U1028:00-AE===
===BECM DTC None===
===PCM DTC None===
===END PCM DTC None===
===OBDII DTC None===
===END OBDII DTC None===
===PACM DTC None===
===DCDC DTC None===
===BdyCM DTC None===
===END BdyCM DTC None===
===TRM DTC None===
===OCS DTC None===
Status (-2F):
Freeze Frame  #1:
-EVENT_TIME: 42663156 s (Fri Apr 05 16:20:50 2024) - Event time
===TCU DTC None===
===RCM DTC None===
===HVAC DTC None===
===GSM DTC None===
===PSCM DTC None===
===ACM DTC None===
===END ACM DTC None===
===SCCM DTC None===
===IPC DTC None===
===GWM DTC None===
===IPMA DTC U0418:86-6C===
- Signal Invalid
Status (-6C):
- DTC Maturing - Intermittent at Time of Request
- Test not complete
Freeze Frame  #1:
-EVENT_TIME: 42663156 s (Fri Apr 05 16:20:51 2024) - Event time
-ECU_INTERNAL_TEMPERATURE: 100 °F - ECU Internal Temperature
===END IPMA DTC U0418:86-6C===
This drive is going to suck, but I don't have the luxury of just sitting and waiting or going straight to a dealer. Gotta get the groceries. Drive a quarter mile over to the commissary, park up and get my shopping out of the way. Come back out to the truck, and this time when it powers on I'm not greeted with the limp mode barrage, just the MIL. Third pull at 20240405 1540z:
Code:
===SOBDMC DTC U1011:86-ED===
- Signal Invalid
Status (-ED):
- Test not complete
Freeze Frame  #1:
-EVENT_TIME: 42663221 s (Fri Apr 05 16:21:56 2024) - Event time
-M_INV_V: 221.60 V - Motor Inverter Voltage
-G_PHTMP: 72 °F - Generator Inverter Phase Temperature
-GCLTEMP: 77 °F - Generator Coil Temperature
-M_PHTMP: 75 °F - Motor Inverter Phase Temperature
-ECT: 106 °F - Engine coolant temperature
-HV_AMP: 1.26 A - High Voltage Battery Current
===END SOBDMC DTC U1011:86-ED===
===SOBDMC DTC U1028:00-AC===
Status (-AC):
Freeze Frame  #1:
-EVENT_TIME: 42663228 s (Fri Apr 05 16:22:03 2024) - Event time
-MODULE_VOLTAGE: 12.8 V - Control Module Voltage
-M_INV_V: 53.40 V - Motor Inverter Voltage
-VEHMODE: Open - Power Sustain Relay  - Vehicle Control Mode
===END SOBDMC DTC U1028:00-AC===
===BECM DTC None===
===PCM DTC None===
===PACM DTC None===
===DCDC DTC None===
===TRM DTC None===
===OCS DTC None===
===ABS DTC U0401:00-28===
Status (-28):
Freeze Frame  #1:
-EVENT_TIME: 42663222 s (Fri Apr 05 16:21:57 2024) - Event time
===END ABS DTC U0401:00-28===
===TCU DTC None===
===RCM DTC None===
===HVAC DTC None===
===GSM DTC None===
===PSCM DTC None===
===ACM DTC None===
===SCCM DTC None===
===IPC DTC None===
===GWM DTC None===
===IPMA DTC U0418:86-2C===
- Signal Invalid
Status (-2C):
Freeze Frame  #1:
-EVENT_TIME: 42663223 s (Fri Apr 05 16:21:57 2024) - Event time
===END IPMA DTC U0418:86-2C===
So what happened? Only thing that comes to mind is that the truck sat long enough that it all of the systems were able to be properly power cycled, since turning the truck off with the key doesn't actually turn the truck off right away. Reset the codes again, and this time nothing came back, code read was completely clean, MIL off, and everything was perfectly fine. Got home no issues, and then proceeded on a 150mi drive to the airport without any problems.
So what's the takeaway? If you get this fail, get somewhere safe, turn the truck off for 5-10 minutes, then proceed on your way. Obviously there's a problem, but at least you don't need to be stuck in limp mode the whole time.
It appears you are in the UK? If you are driving a vehicle spec'd for the US market [you are military, military contractor stationed abroad, diplomatic corps, etc.] file a report with the NHTSA either by emailing them or by phone:
Complaints can be filed through NHTSA.gov or by calling NHTSA's Vehicle Safety Hotline at 888-327-4236.
Have your VIN ready when you email or phone.
Every single Maverick owner who experiences an engine-out incident, [unless you run out of fuel], file a report!
RadioDoc
RadioDoc
Fairchild AFB, WA
2023 Maverick XLT Hybrid Lux
Do you see a problem here? You where going 203.mph in REVERSE.
That can definitely hurt the truck,
Bad memory bit, bad math in an embedded calc routine ( happened to a plane in the Airforce, flipped upside down crossing the equator on autopilot )
Took me a while at looking at this to figure out what was going on here. Given that this code read was taken after my first attempt to clear the codes and while the truck was stationary, I think this is more of a case of a weird null value interpretation or something like that. All other vehicle speeds reported in the freeze frames show zero.
RadioDoc
RadioDoc
Fairchild AFB, WA
Just filed the report online. Was out of country for a couple of weeks so wasn't able to get to it right away. I'm hoping that I get some kind of fix for this from Ford, although I'm still trying to get them to update their systems to show that I actually own this truck.
Jay C Spike
Jay C
Northeast Texas
2022 Maverick Hybrid Lariat
Code:
- Signal Invalid
Status (-AF):
Freeze Frame  #1:
Status (-26):
===BECM DTC None===
Status (-AF):
Freeze Frame  #1:
Freeze Frame  #2:
Status (-50):
===PACM DTC None===
===DCDC DTC None===
Status (-08):
Status (-08):
===TRM DTC None===
===OCS DTC None===
Status (-2F):
Freeze Frame  #1:
Status (-2E):
Freeze Frame  #1:
===TCU DTC None===
===RCM DTC None===
===HVAC DTC None===
===GSM DTC None===
===PSCM DTC None===
Status (-28):
Freeze Frame  #1:
===SCCM DTC None===
===IPC DTC None===
===GWM DTC None===
- Signal Invalid
Status (-AF):
Freeze Frame  #1:
Code:
- Signal Invalid
Status (-AF):
Freeze Frame  #1:
Status (-AE):
Freeze Frame  #1:
===BECM DTC None===
===PCM DTC None===
===PACM DTC None===
===DCDC DTC None===
===TRM DTC None===
===OCS DTC None===
Status (-2F):
Freeze Frame  #1:
===TCU DTC None===
===RCM DTC None===
===HVAC DTC None===
===GSM DTC None===
===PSCM DTC None===
===ACM DTC None===
===SCCM DTC None===
===IPC DTC None===
===GWM DTC None===
- Signal Invalid
Status (-6C):
- Test not complete
Freeze Frame  #1:
Code:
- Signal Invalid
Status (-ED):
- Test not complete
Freeze Frame  #1:
Status (-AC):
Freeze Frame  #1:
===BECM DTC None===
===PCM DTC None===
===PACM DTC None===
===DCDC DTC None===
===TRM DTC None===
===OCS DTC None===
Status (-28):
Freeze Frame  #1:
===TCU DTC None===
===RCM DTC None===
===HVAC DTC None===
===GSM DTC None===
===PSCM DTC None===
===ACM DTC None===
===SCCM DTC None===
===IPC DTC None===
===GWM DTC None===
- Signal Invalid
Status (-2C):
Freeze Frame  #1:
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
If the update does not successfully complete the. It needs to be reapplied. The tech most likely needs to put a 13+volt power supply onto truck while performing update.
This is a really good point. When I did my latest Sync upgrade at home, I left the truck on a tender for 24hours before performing the upgrade. Some of these hybrids seem to drop voltage pretty quickly when not connected to an outside power source.
Someone did post a memo or instruction to ford techs that required them to place at least a 13 volt supply on truck when doing updates. The reason was to insure that the BMS would not shed (turn off dome light circuit or one of many other items) during the installation. (Presumably if a circuit is off then the update will not recognize that option as being installed and won't update that function???)
RadioDoc
RadioDoc
Fairchild AFB, WA
Hey look, there's a fix!
Campaign/NHTSA#
24S33/24V330
Issue Date
2024-05-03
Description
Our records indicate that your vehicle recently received an update to the hybrid powertrain control module hpcm software calibration. This hpcm software can result in a forced neutral condition while driving resulting in the vehicle coasting to a stop and automatically shifting to park, along with a wrench light, multiple warning messages in the instrument panel cluster and an audible chime. After shifting back into drive the vehicle will enter a limp home mode which provides limited torque at low speeds up to 30MPH.
Safety Risk
A loss of motive power can increase the risk of a crash.
Remedy
Ford Motor Company has authorized your dealer to update the powertrain control module pcm software free of charge parts and labor.
steegro
Las Vegas, nv
Lexus nx 200t
Limp mode just happened to me 3 days ago on my 22 Ford Maverick Hybrid XL. I got the recalls done in early March. Taking it to the dealer tomorrow but talking with them on the phone, they didn't seem to be aware of any updates. Submitted my report to NHTSA.gov. Was an amazing truck up until this point. What a pain all these recalls are!
23grayXLT84
Midwest
23 hybrid xlt
Find a new dealer.
Input your vin on Ford or NHTSA website and check for open recalls. One was released not that long ago shown below.
May 10, 2024
NHTSA CAMPAIGN NUMBER: 24V330000
Software Error May Cause Loss of Drive Power
A loss of drive power increases the risk of a crash.
If your vin falls under it, there is a good chance this is it.
steegro
Las Vegas, nv
Lexus nx 200t
Find a new dealer.
May 10, 2024
Bummer. Nothing like that pulls up when I enter my VIN. Only the under hood fire and body control module are available.
RadioDoc
RadioDoc
Fairchild AFB, WA
I don't think my truck was ID'd as due for this recall until I put in the NHTSA report.
CurtisB
Find a new dealer.
May 10, 2024
It simply amazes me how the dealers remain completely clueless on this stuff. Come on dealerships, check your update notifications, check your email notifications. Get with the program! In an era where everything is "instant" how can you not be up to speed? If I was a service manager and I customer came to me with this complaint, the FIRST thing I would do is research any possible history through Ford updates. Secondly, I would call as many local dealerships to inquire about this and get the hell up to speed on it.
TedTX
Ted
San Antonio TX
Got the re-recall notification on Ford app. But missed the first recall by a day. Got all the software recalls open before these related three. Still need those done. Haven’t experienced the limp home mode myself.
