- First Name
- Douglas
- Jan 29, 2025
- Warner Robins
- 2015 F350; 2025 Maverick Lariat
- Engine
- 2.5L Hybrid
Learned (and relearned) a couple of things about towing. We previously had a F-350SRW pulling 30' 5th wheel, so I thought I had this wired six ways to Sunday. Not, as it turns out... 2025 Hybrid Maverick with 4k tow package installed. Towed across Florida from Venice to St Augustine and then to Warner Robins GA, using a U-Haul 5X8 trailer, weighing about 1,800lbs combined weight.
1) Use the provided calibration sticker. I practiced backing without one and then used the calibration sticker and it helped the truck to "see" the tongue and its movement. I got 3 stickers with the truck (found them in an envelope in the glove compartment), but apparently, you can get more from a dealership (not sure if they charge for them).
2) Adaptive cruise control doesn't work in tow/haul mode. If you want cruise control, you have to go change it to normal cruise control on startup.
3) When backing using the Ford PRO system, go SLOW, as in 0-1mph, especially with a short trailer.
4) If there is difficulty getting the Ford PRO system to "detect" your trailer (despite connecting to the trailer on startup), try cleaning off the side view mirror and tailgate cameras. It had been raining and the rain/spray on the camera lenses screwed up the vision system enough to prevent it from working until I got a rag out and cleaned them off.
5) Spotters are still a good idea, even with fancy camera backup systems.
6) Mileage dropped from 33MPG normal highway to 22ishMPG while towing. Kept it under 65MPH, mostly 55-60MPH. Not too shabby, but with a 13ish gallon tank, I got range anxiety, just as I had with my diesel F-350 pulling our 5th wheel.
7) Don't believe the miles to go calculation when towing, it's a LOT less. I dropped down to the nearest round number multiplied against the estimated remaining fuel so I'd be not caught short of a gas station. So, 20MPG times Y gallons to come up with distance to empty (conservative estimate).
8) Empty trailers make a lot of noise on your hitch, as it bounces about in the receiver (not sure if there is a sleeve solution to prevent that). Loaded up, it was nice and quiet.
Anyways, some thoughts I had , hope it helps someone.
