I finally had enough of the Lasfit bulbs burning out in less than 6 months. I called Lasfit and they were nice enough to send out replacements again for the burnt out brake lamps. They did “upgrade” me to the new T3 lamps. I tried them and were very bright when you first turned them on, however after about 4 minutes in of being on, they dimmed down to a 1/3 of there brightness and were freakin on fire they were so hot. I started looking at some ALLA MIN RED on Amazon. Order 2 pairs and WOW. They are projector type bulbs that have a very powerful beam straight out the front with enough spill on the sides. I ran 1 ALLA MINI against the Lasfit T3 in the Same housing. Major difference . The ALLA stayed bright the whole time while the Lasfit tanked down to a glow in around 5 minutes. If Lasfit could come up with a bulb with a larger heatsink to handle the overdriven LED , that would be great. Instaed they just thermal the driver down to unusable level. T3 must stand for Thermal down in 3 minutes
