LASFIT replacement bulbs (T3-4257R) installed
A.Bursell
Stanwood, WA
Their product in my experience is not junk. As I have posted, they are working well on two vehicles that I have modified.
You posted that you used Forscan to make changes so that the bulbs that were supposed to work without any changes would actually work.
That alone makes them junk.
A.Bursell
Stanwood, WA
Lasfit is not manufacturing them any more. Diode Dynamics has a solution involving adding inline resistors, but I am not sure if they are doing this any more.
Resistors are a universal solution for nearly any vehicle. Many companies did this before the Maverick was even on the drawing board, and many companies continue to do this. It's not a Maverick exclusive thing.
I am partial to Diode Dynamics and their products. But others do too.
A.Bursell
Stanwood, WA
Does anyone know if the 2025’s make more use of LED’s?
I noticed in the latest spec sheet that it shows Lariat/Lobo as using LED taillights. But haven't seen any evidence of that, nor does it mean it's accurate, as they do sometimes have errors. Could be just referring to the signature LED like the current taillights have.
SloopJB
Waxahachie, Texas
2025 Maverick Lariat ECO/AWD White with BAP
Get a life. I enjoy making things work. I speak of my experience which has worked flawlessly for going on nine months now. Just to add another bit of experience, I bought the original Lasfit without the resistors and they worked fine, except for the dreaded hyperflash. But I didn’t know about the FORScan solution and when Lasfit sent me the new version, I gave the original Lasfit to a friend cause by then, I learned of the FORScan solution anf modified his module. He is not experiencing any hyperflash and he is happy with them. By the way, the original bulbs were brighter.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
That is not true! The light assemblies can be easily removed and the bulbs are simple to remove. It took me only 5 minutes to changeout each side. What you said is true for the headlight assembly, but not for the subject units as per my post.
I think you might have misunderstood me. What I mean is that you can only replace the factory halogens with LEDs. I know these are easy to do, done it myself before putting the halogens back because the LASFIT stuff is junk that doesn't last. I had the first gen stuff, half of them are dead after 1 1/2 years. None of the factory LED lights are user replaceable bulbs.
A.Bursell
Stanwood, WA
You enjoying paying extra for things that don't work right and then fixing it. Got it.
I don't reward companies that make false promises and rip people off, I call them out. I'll also let people know which companies to support as well. I have done both many times here and helped a lot of people.
I think I've got a pretty good life, actually.
SloopJB
Waxahachie, Texas
Good points. I was looking for a simple low cost option that I could do without cutting into the wiring harness for the installation of the resistors.
I apologize for my offensive comment. I may be changing my opinion down the road if they begin to fail, however I have 5 spare bulbs to go through first. (Lasfit sent me 5 packages when I complained about one bulb not working right out of the package - don’t know why they sent so many.)
I wish the original Lasfit solution without the resistors was still available
SloopJB
Waxahachie, Texas
For those of you that have had good luck with Diode Dynamics know whether or not the D.D. LED lamp without the added resistor would work, thereby depending on the FORScan disabling approach.
freddievw
Frederick
kc,mo
2025 Maverick Hybrid lariat trim
I'm seeing a lot of posts about replacing the factory bulbs.is there an issue I should be aware of? Ours seems fine after a year of ownership.
Chris Helfrick
Hanover
2024 Maverick XLT 2.0
I bought a set of Lasfit DRL/turn signal lights right after I bought the truck in October of 2024. First set failed within 4 months. Replaced under warranty. Replacements were of a different design. They have been in for over a year with no issues.
