EONR24
Swag
United States
2024 Ford Maverick XL
Some hybrid owners are doing this mod and the last coding 720-10-02 doesn't need to be there and is messing things up for the hybrids
EONR24
Swag
United States
How to add Lane Keep system without Copilot 360 package. This has been tested on a 2.0L XL w/o copilot and 4k tow package. Hybrids will have different foscan settings for certain registers, key valid for both unless specified otherwise. 6 inch cluster screens may also need different forscan hex keys for the same applicable settings in the IPC 720-xx-xx registers.
All trims already come with a front facing camera and image processing module so all that is needed is the correct turn signal stalk which costs about $35. All you need to do is swap the turn signal stalks and activate with forscan. It is valid for all trim levels without Copilot 360.
After swapping the stalks (quick write up to follow) to turn on the lane keep system which includes Lane keep alert, lane keep aid and driver alert system these are the following forscan codes. Should work on all builds except where noted.
Vehicle tested on 2022 XL w/o copilot 2.0L ecoboost and 4k tow package
To get the button for lane keep working first you need to set the following codes.
IPMA
706-01-01
044D 59C9 B537 - 2.0L ecoboost engines
0B4D 59C9 B53E - 2.5L hybrid engines
This activates the functionality in the image processing module
PSCM
730-02-02
FFFF 0000 0039
This activates the power steering functionality for wheel vibration and correction.
SCCM
The middle part of the code specifies you have the lane keep left turn stalk installed the other lines refer to the steering wheel buttons.
724-02-01
1228 A820 3060
Steering wheel buttons w/o cruise control, switch combo SW8588 / SW8589
1258 6820 3050
steering wheel buttons w/ cruise control, switch combo SW8576 / SW8579
If any one of these 3 is incorrect the button won't work and you'll either get no lane keep icon in the cluster screen or it will be there but you won't be able toggle it on and off.
Next are the codes for the instrument cluster. These should also be valid for the 6 inch cluster screen. If you have issues get some as built data for a Lariat with the lux package and change whatever values differ for the same register addresses.
IPC codes
720-01-02
0227 4093
This activates the driver alert system option in the options
720-02-01
09E4 2D34 1E96 - 2.0L ecoboost engines
09E4 2D35 9E17 - 2.5L hybrids engines
This activates the lane keep menu, alert and aid settings.
xxxx xxxx Xxxx is for how mpg is calculated and shown in the trip screen
xxxx xxxx 1xxx = gas
xxxx xxxx 9xxx = hybrid
720-09-01
2042 1440 1900
This enables the lane keep steering wheel vibration and correction intensity settings.
This next section of codes enables the Driver Alert System. If any of them are not set it will not enable when you have Lane Keep on and the driver alert option setting in the vehicle settings
BCM codes
726-15-04
0147 - 2.0L ecoboost engines
Leave setting stock for hybrids as of now. Needs testing to determine if the code is 1 needed to be changed and 2 specific to the vehicle regardless of trim when a hybrid engine is installed.
IPC codes
720-05-02
0840 0379 - 2.0L ecoboost engines
0800 0339 - 2.5L hybrid engines
720-10-01
1800 0001 0253
720-10-02
0100 407A
The whole system to this point will work almost 100% correctly. The only issue is when you enable mykey it is supposed to according to the manual, keep the user using a programmed mykey from shutting off lane keep. So far I haven't been able to do that with a programmed mykey.
edit
A sideways workaround to the mykey issue is to disable mykey functionality outright. If you don't use mykey you'd probably do this anyways.
For register 720-01-01
Leave everything else alone and change the following to 9
xxxx x9xx xxxx
example
09E4 2D34 1E96
becomes
09E4 2934 1Exx
You'll get a checksum error message, go ahead anyways and hit okay and forscan will correct the last 2 digits to the correct checksum for the new setting before writing. The Lane Keep settings will still function normally and if you have a programmed mykey it will function like an unprogrammed key. Turn the setting back on, the programmed key will then function as it should.
Other than that it doesn't throw any error codes and the features work as they should.
Before anyone asks I am not going to do a write up on how to install BLIS afterwards. It can be done but the cost of the parts alone costs more than just having Copilot 360 installed as a factory option.
Delete the part I highlighted in the red in this quote. thanks
EONR24
Swag
United States
the 720-10-02 coding is only changing something that has to do with GAS vs HYBRID and has nothing to do with the lane assist mod!
EONR24
Swag
United States
720-05-02 Is wrong its for a trailer brake.
EONR24
Swag
United States
I don't think the bcm coding needs to be done at all either
DrewsMav88
Andrew
MA
24 Mav
Has anyone done this to a '24 XLT? Should I do anything different than the original '22 instructions?
Ray-n-AVL
Ray
Asheville, NC
2024 XL Hybrid (Black), 2009 Yamaha V-Star Tourer
So I made all the (EZ) changes via the master spreadsheet (for no stalk) and everything is working correctly. Now if I replace the left stalk with the one with the button the only thing I should have to do is DISABLE the IPMA (EZ) "Customer Preferences - Lane Keep Support - Vehicle" to make the button work to turn it on or off?
Thanks,
Ray
pantera156
Pantera
Porto Alegre
lariat 2.0
Funcionando :clap:
psychodad1961
Jeff
Saginaw, MI
2022 Ford Maverick 2.0L Ecoboost XLT FX4 Off Road.
I'm late to this party, but would like to report I have successfully programmed in lane keeping/driver assistance using the instructions in the first post. Thanks for that. Instead of changing the stalk, I ordered some little black pushbuttons and soldered one to my existing turn signal stalk. In the pictures in the instructions above, It shows 4 little wires soldered to 4 pads on the circuit board. I investigated and it turns out that the 2 solder pads on the left are connected together and are at ground potential. the two on the right are also connected together, and will turn LKA and DA on or off when momentarily connected to the left two pads (ground). The switch cost me about a dollar (pack of 10=$11.99 on amazon).
But, I seem to have lost my Traffic Sign Recognition. Anybody have any insight on how I might get it back? Checked Forscan settings, all appear to be correct. The circle is in the cluster and the option is in the menu.
hungliketictacs
Austin
Maverick EcoBoost FWD
I've had this happen before when I went in for service, I would suggest you run through the instructions again and you'll most likely find a setting reverted.
Prawn
Luke
2023 Hybrid XLT
So I just did this for a second time. First time worked great, but now none of my steering wheel buttons work. Any ideas
Prawn
Luke
2023 Hybrid XLT
Never mind I fat fingered a number. All is good
Camo51
Rafael
TX
2024 Ford Maverick XLT FX4 4K-tow
IPMA
706-01-01
PSCM
730-02-02
FFFF 0000 0039
SCCM
724-02-01
1228 A820 3060
1258 6820 3050
IPC codes
720-01-02
0227 4093
720-02-01
720-09-01
2042 1440 1900
BCM codes
726-15-04
IPC codes
720-05-02
720-10-01
1800 0001 0253
720-10-02
0100 407A
edit
xxxx x9xx xxxx
example
09E4 2D34 1E96
becomes
09E4 2934 1Exx
Thank you so much man... I got lane assist now!
