Does anyone know if it’s possible to erase the factory code or disable it altogether?
I thought the manual gave instructions on how to reset the codes. What do you mean by "factory code"?Does anyone know if it’s possible to erase the factory code or disable it altogether?
Maverick is hardwired; in the assembly video floating around this site and YouTube, you can see at the factory that a stamped cutout is in the drivers door vs ranger for instance, which is just an adhesive dealer installed option that runs off its own battery.Does anyone know if the keypad is wireless or hard wired. It looks different than the wireless ones I have seen of the Bronco.
That's good news as one can no longer reprogram the wireless keypad like in the old days with the ignition key. Gotta go to a Ford dealer or someone with the special tool. Thank you.Maverick is hardwired; in the assembly video floating around this site and YouTube, you can see at the factory that a stamped cutout is in the drivers door vs ranger for instance, which is just an adhesive dealer installed option that runs off its own battery.
It is not possible to erase or change the factory code.
the only option is to add/erase user created codes.
Ma manual says no.....even if you program a new code, the master code will always work. I hate that! Can't stand not have control over the keypad system.Does anyone know if it’s possible to erase the factory code or disable it altogether?
