Issue installing software update
csfd1996
South Florida
Ford Maverick XLT Hybrid
I have been attempting to download the latest software update with no luck. I connected to my wifi about 30 ft from the router and it did not download. I then hooked up my cellphone as a hot spot and that did not work wither. Any ideas why this is happening?
Ford Maverick Issue installing software update IMG_8357
Ford Maverick Issue installing software update IMG_8359
Nomav
Stephen
NC
2021 FJG Mach 1 HP
I have gotten lucky a few times on other cars but I recently had issues with my mustang and ended up saving the file to my USB which is much easier and you can do the update while driving instead of letting it sit wasting gas. Hope this helps!
matmondro
Mathieu
Vassar, MI
When I did the upgrade (maybe a month ago? Can't remember when...) I literally just had to try to initiate it like three times. My wifi has two bands, 2.4 and 5 GHz, I believe I connected it to the 5 GHz band. You also have to keep the truck in park and at the very least the ignition on. I just left the truck running. Hopefully it'll work eventually! Just one of those things where you just have to prod it enough.
AltoBAP
Jefferson
Metro Detroit
2020 Ford Fusion SE 2.0 AWD
Welcome to Ford ownership.
csfd1996
South Florida
i think it came out in early March.
AceGoliath
Charles
22 Maverick XLT, 21 Bronco OBX SAS, 10 Fusion SE
I just got 2.1.0.1 on Monday. Up from 2.0.0.1 from around October.
Ford Maverick Issue installing software update 409B8DE9-31FE-4464-B33C-5F56D50A6AF9
Hammer
Easton PA
2009 VW GTI
Hammer
Easton PA
2009 VW GTI
Hammer
Easton PA
2009 VW GTI
I completed this update today with no issues. I had asked my dealer to complete it last week when it was in for airbag recall, but I found out a day after picking up it was not done and I called the dealer and they said my vehicle showed no updates needed when they connected to it ( I’m not sure if I should believe that story ).
It took about 10 minutes to download ( 200 Meg Cable modem Wi-Fi ) with the truck running while sitting in my garage. After download completed I had to do a soft reset ( holding power button and >> button for 5 seconds ) to get the software update to register.
Maybe your Wi-Fi signal is not strong enough in the area your Mav connects? Wireless signals can get blocked and degraded depending on many factors related to the physical layout of a house and/or signal interference
Chris_G
NOVA
C-6 Corvette
Yes, it frustrates folks trying to install it.
NotAnonymous
Indiana
I ended up going the USB route too when I previously updated the software....
