Is this normal? Height of tire from fender question
MaverickSVT
Ohio
2000 Ford Contour SVT
The 2 back rears are approximately 7” on each side when measured this way.
I noticed that the passenger side front has a little more space about 5.5” whereas the driver side is a little less than 5.250”
About a 1/4” difference, maybe a little more than a quarter inch from side to side on the fronts.
All 4 tires are equally and properly inflated and all 4 are worn evenly and have been rotated every 5k.
22k on the tires
Is the truck slightly heavier on the driver side front to cause that little difference and is that normal and how these are made?
thanks
Ford Maverick Is this normal? Height of tire from fender question IMG_1897
Ford Maverick Is this normal? Height of tire from fender question IMG_1896
BigClydeLittleTruck
Clyde
22k on the tires
thanks
You got my curiosity up so I just went and took the same measurements on mine. I have a Tremor so the heights are different than yours but my driver side and passenger side measure the same - which is what I would expect. Maybe others will report to give a fuller perspective overall.
Good luck.
IMO i would think they should be equal. Anyway you might have a broken shock or other suspension component on the side that is lower?
Cancunbadlands
Cancun
Cancun
Tremor owner, driver side and passenger side measure the same both
commadorebob
Silly question, but are you parked on even ground? I could see a case where the front driver side is sitting up higher in the wheel well if the tire itself is parked on slightly higher ground.
MaverickSVT
MaverickSVT
Ohio
I’m in my driveway it should be fairly level
Chops
Lobo
22k on the tires
thanks
I once had a Volvo with the notorious “Volvo Body Lean”. Seemed like a 500lb driver was behind the wheel!
Since your tires are the same & the rear is level - maybe a fender(s) panel is out of spec? Would not be the first time. Maybe take a few more measurements in addition to the wheel clearance? Look for any uneven gaps at body panels or hood on both sides?
Does your Maverick drive straight like it should or does it pull slightly to one side or another? Hit any big potholes lately? Good luck with the mystery:)
MaverickSVT
MaverickSVT
Ohio
Seems to drive straight and perfect.
What would hitting a pothole have to do with this issue?
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
Wow a 1/4''. You need to get out more.
Chops
Lobo
Maybe a big pothole or a Dukes of Hazard style ramp jump could throw the suspension out of whack?
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
I’m not sure why you decided to measure in the first place? You say no problem and tire wear is fine,etc… but to answer your question 1/4” is really within reasonable range for sure & yes the back is higher than the front (for loading it up). I myself did measure roughly the same when I first lowered mine.
M-ervin
2023 Maverick Tremor
22k on the tires
thanks
Try turning truck around and park in same spot. Just to verify.
MaverickSVT
MaverickSVT
Ohio
It looked visibly low on driver side.
Of course the back is higher than the front there is no engine in the back. Way less weight in the back.
Marty
2026 Ford Maverick Tremor
The battery is on the driver side, hence a quarter inch sag.
I just made that up, but go with that and
Fagetaboutit !
