Is this a CV boot issue or something else
Johnnybayday
Orange County, CA
www.coastalfamilydental.com
Ford
Hey guys I just want to try to confirm my issue before sending it back to Ford for a warranty fix. Pleas turn up your volume before viewing.
Making a funny squeak noise during acceleration and I little rattle.
Do you guys think it's a CV boot issue or a motor issue?
bajesus8
Olathe, KS
2022 Lariat Hybrid Lux
Mine would rattle/shake getting upto highway speeds then gradually go away as you let off pedal.
Yes, your CV axle is bad, one of my axles did this at 20k, replacement was free at dealership.
just call em, tell them you suspect bad CV axle and describe what's happening. they should get you in next day and have your truck ready by end of day.
If you drive like this too long it may wear down your drivetrain mounts. Mine was always stock height so im not sure being lifted has anything to do with it.
azmotoxxx
Wes
Gilbert
I'm slightly lifted... Just a leveling lift in the front. I'll make a call and see if they are willing to order parts first before I drop it off
Any updates on your truck? Mine is doing the same thing!! So messed up I have to take my truck in with 20k miles to fix this bullshit! I’m assuming it just keeps happening, this a bad design? Probably need a better aftermarket part? Otherwise we might need new ones every 20k miles?! Ugh
Johnnybayday
Orange County, CA
Ford
I just looked under my truck... Goopy grease all over the passenger side CV joint by the engine... What a mess... Will call Ford tomorrow so they can order parts and get it fixed... My question is do they fix both sides or just the messed up side? There should be a tsb or recall or this... Whack!
azmotoxxx
Wes
Gilbert
That sucks dude. I put mine on a lift and took the wheels off and looked at everything. Nothing leaking and no grease coming out of the boot. Mine is doing the same thing in that video, the weird @ss noise and vibration from hell…feels like the front wheels shake the entire front end under any decent amount of acceleration only. Lame as hell Ford! I’m so pissed.
azmotoxxx
Wes
Gilbert
Are you concerned this will keep happening? Seems like they need to get this figured out. I’m not rough on my truck at all. Wish there was a better aftermarket cv axle that was bulletproof. If I’m taking it to the dealer every year or two, then my Maverick is dead to me.
azmotoxxx
Wes
Gilbert
Thank you for sharing this video! Mine is identical to this. Did you get yours fixed? What is the scoop? Thx!!
bajesus8
Olathe, KS
Check the thread about interest in aftermarket CV Axles.
The dealer will repair only the broken one if the other axle is fine.
BoskoPColtrane
Bosko
I don’t think we can determine your issue. I would just take it in and get it verified.
Ford Motor Company
Official Ford Account
Dearborn, mi
rcereghino
Rodolfo
Chile
Maverick 2024 Lariat
What years Mavs are having issues? Mine is 2024
bajesus8
Olathe, KS
OP stated he looked under truck already and saw his CV axle had de-greased itself all over engine.
Im not concered. im sure we will get a solution either from ford or aftermarket thats a resonable price eventually. i have an extened warranty that will keep covering this, once its over, if ford hasnt already replaced everyone's with better designed unit with a recall then ill just go aftermarket.
Nw_adventure
Salt Lake city
Is it normal for the passenger side unit to fail first ? Mine did @ 19k -
bajesus8
Olathe, KS
