interior lighting
glider
So Cal
2002 4runner 2019 Honda civic
When I open the driver door I have no interior lights come on. I have a lariat and no ambient lights either. I have tried the settings etc. Am I missing a switch? Battery seems fine. No other issues I know about. What am I missing? Thanks.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
There is a 3-position switch on the overhead centre console that controls how the interior lights work. It should be in the centre position.
Ozarkbeard
If it's not the switch above the rear view mirror, your battery probably is in battery saver/sleep mode. In this mode your hybrid should still start, as the 12 volt battery only operates relays to make the high voltage battery put the truck in ready to drive mode or start the gasoline motor if needed.
If it happens again after your next drive, get a battery maintainer and put it on the jump points under the hood. The user manual tells you where those are. They are on the driver's side. Keeping the 12 volt battery from getting too low will also prolong its lifetime. NOCO is a good brand and available at Walmart or Amazon.
Montana
It's a known issue of deep sleep but if you are doing okay above deep sleep voltage they should come on when you open the doors as long as the switch is in the correct position.
I think ambient light only comes on once the vehicle has been started? I can't remember. But if it's not on while you are driving, then the only other spot is the setting within SYNC's options.
glider
So Cal
Yes. The switch is in the center position.
glider
So Cal
Thanks for the reply. I don't think it's in deep sleep. The lights work when I turn them on at the switch.
Hmm.
Hmm.
Does your instrument cluster start booting up displaying the truck animation and radio the Ford logo when you open the door or only when you push to start? Both will stay blank if it's in deep sleep. Also the passenger side intelligent access disables.
Also the ambient lighting has a tendency to just randomly shut itself off and needs to be turned back up in the settings. Maybe the radio update CSP addresses this.
Carlitos_92
I am not familiar enough with Lariats to know what all will trigger the lighting, but I'd also be curious if any other doors will activate the lighting. Maybe the position sensor for that one driver's door is broken?
glider
So Cal
That stuff all works. I don't think it's a deep sleep issue
glider
So Cal
Ya, thanks. I tried that no luck.
MaverickMark
2023 Maverick Lariat
It's sleep mode. Happens to me everyday. If you have the ford app, it should alert about going into sleep mode. When it's in that mode, the interior lights won't come on. It annoying for sure.
glider
So Cal
Thanks I was hoping that wasn't the case. I'll hook up the ford app and see what it says. I shut down the app the day I got my truck thinking that might discharge the battery.
MaverickMark
Sorry brother, I have a Lariat too. Other than that issue, the truck has been great for me.
Swede
Butler, Pa
22 Maverick Lariat, 19 Subaru Outback, 01 Saab 9-5
I don't have a hybrid and I have the same lighting issue. Do non-hybrids go into sleep mode?
