Intelligent AWD menu screen missing? - 2024
The-X
Midwest
Maverick XLT
I've gone to the "my view" thing a dozen times (like the manual says) and all it has is
-digital speedometer
-mpg
-calm screen
Did they remove ALL the other options? Ie in the last recall fix which was some digital update.
Namely the one I'm looking for is the "Intelligent AWD" screen. The one that would show you where power was going.
I knooow I've set it on in the past even and now I can't find it at all. And really hadn't thought about it til we got a little snow and I was curious how "slick" did differently than normal driving.
On that line I can feel the difference namely in RPM that the AWD is sending more power to the rear vs normal drive.. and of course ironically the time you most don't want to be looking at where the power is going is often when you should be paying attention. My curiosity came in that I noticed the rpm was fairly higher even when just driving straight, so I wanted to check it out, that's when I noticed the screen was missing in the menu.
Hunters Edge
Sid
F150 crew
-mpg
-calm screen
I don't know if this will help but how are you going through the different screens? If you are just scrolling up or down you will or should see what you have previously checked. It limits how many screens you can access. If you want to add or delete screens, click on menu. Click on can't remember but you can see what screens are checked or available. You then if you don't want to use that screen click on it to remove it if you want to see that screen shot click and leave the box checked. Again you can only have so many boxes or screens available. Once you have the intelligent AWD screen checked you can hit menu to back out. Now using the toggle you can go through the screens you have checked in the boxes. Hope this helps, if not, I haven't a clue why you are not able to access the intelligent AWD screen. Good luck
The-X
The-X
Midwest
Maverick XLT
In the main list there's
My view
the trip menu
phone
radio
driver assist settings
settings
It was originally under "My view" I feel like but now it's just those 3 options, speedometer, mpg, and calm screen.
d7602002
Joseph
2024 Maverick XLT
I have that I think. I go to the screen that has the truck picture, hit the menu button, then select information and then the AWD one. It's the same spot where you can check your tire pressure. At least on mine.
Toddman45
Todd
St. Louis, MO
Better trade it in on a 25.
The-X
The-X
Midwest
Maverick XLT
Ugh YEP that's where it was.
Settigns>Information>"intelligent awd"
I was hoping it was in the "my view" section so I could go to it easier. Not that I use it a lot again... but it'd be fewer steps.
Well mystery solved.
Jpalmer1
Dallas, TX
2025 Lariat Hybrid AWD
I still can't find it! Any 2025 Hybrid AWD Lariat Owners out there found the AWD Screen?
chadrob30
Chad
Greenwood, Arkansas
2011 Tundra
This is the answer
Jpalmer1
Dallas, TX
@ d7602002 . . I've tried that, but nothing there. Are you confirming that on a 2025 Hybrid AWD?
Jpalmer1
Dallas, TX
Probably just the 2025 Hybrid's since the AWD is new to them this year.
