Intake noises - anything to be gained?
dalola
Retired
SE Ohio 🇺🇸
No, travel long road trips so I use an adjustable octane performance tune from Gearhead. Anything from 87 to 93+ works but mileage and performance are best with 93 octane 10% ethanol common local mix. Odd combo a light RCSB 2wd 3.73 gear, leveled on large 285-70-17s. Best mileage is the home 93 blend at 27 highway mileage, 87 drops near 6 MPG and is close to the cost of the 93 I use at home. Fun thing with my setup is the responsiveness. The snail pump so fast that LAG is near undetectable, this required learning a new driving style to keep the back end in line! I drag raced a street stock 1968 Z28 in the 70's (low 13 second ETs), my F150 is quicker!
I had an E85 tuned '18 2.7 F150.... I've never seen a gas tune get 450hp on a stock 2.7, do you have a dyno chart?
F150 2.7 TT user
Kenneth
SE WI
2017 F150 XL 2.7, 2016 Edge Sport
Ford Maverick Intake noises - anything to be gained? 1782782229686-id
380 HP and 476 torque on 93 octane. I was using the 10x conversion of exhaust air flow (44+ pounds WOT) for HP at the crankshaft. Crank HP vs rear wheel difference.
dalola
Retired
SE Ohio 🇺🇸
Gotcha. That is in line with typical 93 perf tunes. The 2.7 has a ton of margin....
Nw_adventure
Salt Lake city
Like I said earlier- The S/B intake checks lots of boxes while not brining John Force/338 mph 1/4 drag passes- Its a nice upgrade for those that are into that thing- You know making your truck your own -
This is always a fun topic- I myself really enjoy having this S/B intake on my FX4- Just a touch more intake growl and a little BOV whoosh addition but still quiet as can be. Its got a little more butt in seat oomph - The way that Ford limits the turbo PSI when accelerating from a stop gets in the way of the fun, an intake cant fix that along with the transmission that gets confused when you want the beans so it is what it is- For me I was just happy getting rid of that POS/OEM filter housing assembly- I went with the dry extendable unit -
The fit and finish of the S/B intake is top notch- BTW
The folks that get a fancy for the light trash talking of "OMG Becky why would you do this intake ? " Are probably the ones sword wresting over an $8 saving on an OEM type windshield wiper replacement @ Costco -
Chops
Lobo
$379 & no dyno results = a kick in the wallet nuts
Dyno results for $379 haha. It costs thousands & thousands to get significant dyno results.
$379 gets you a better sounding EB - if you’re into that kind of thing. $379 for a sound system upgrade is a bargain to be frank. Some spend more:)
Nw_adventure
Salt Lake city
No large scale MFG unit pumps out dyno reports, too much potential litigation and nonsense. K/N comes to mind- Folks can arrange there own with a local tuner if need be.
Mudduck
JD
Utah
100%
It is crazy to see people make statements like "The stock intake is good to 500 hp" but cant prove it in black and white. Its like "Ill dispute your opinion with louder opinion" because everyone knows the more loud you are, obviously the more correct you are.
Some mods do not do much when stand alone. There are mods, and then there are supporting mods. "Most" people do an exhaust for the sound alone and there isn't much flack about it. But, when it comes to an intake it is seemingly taboo for many. My intake increased the PSSSHHHHH, and WOOOSH, engine tone is now what i like and increased/smoothed out throttle response, and seems to have a very slight uptick in fuel mileage, though it's negligeable without long term tracking.
Air in/ Air out, I don't need a dyno sheet to confirm an intake works. Show me 1 modded Maverick dipping into the 11s without an intake on.
Just my .02
F150 2.7 TT user
Kenneth
SE WI
Nothing wrong with personalized bling for the vehicle! But calling the stock CAI a POS is overdoing it. They are NOT pretty but they work as well as any aftermarket CAI. Hell I have a COBB twin tube CAI on my F150, wanted to find out if independent intake runners would make a difference. Butt dyno said yes, timed runs 0-80 MPH said no (it slowed down). This started a week long series of experiments for a retired motor head to wrap his fat head around. Equipped with a Draggy and monitored exhaust air flow experiment ensued. From no filter at all thru a bunch of configurations I managed to get better 0-80 times with the COBB CAI modified to use the stock style panel filter. This was a fraction of a second fastest over averaged runs, not any real gain but consistent. It is a closed air-box as I did not want any under-hood air in the intake. I does look good though, once past the plumbers nightmare on top of the 2.7!
Ford Maverick Intake noises - anything to be gained? PA160002
F150 2.7 TT user
Kenneth
SE WI
"Show me 1 modded Maverick dipping into the 11s without an intake on."
If I had an 11 second 1/4 mile anything there would be some bling/fancy intake on it!
Marty
I call them a More/Air intake- Any real reduction in temps would need to have A Nasa/Heat Shield type coating and some other Eskimo magic - That turbo gets hot as heck -
That’s the main reason the auto stop/start is so so stupid.
Suddenly depriving a very high speed turbo of oil pressure.
THAT is unbelievable dumbassery from FORD.
F150 2.7 TT user
Kenneth
SE WI
Auto start stop, I'm no fan but at least that was considered in the engineering. The turbo is attached to the head but quite low and oil draining will pass thru the turbocharger. Ecoboost also use an auxiliary coolant pump, on my 2,7 it is electric and keeps coolant flowing after engine shut down. A much better system that past turbo motors. Hell I owned a 1966 Corvair Turbo Monza in the 1970's and that had nothing but an oil line and sat well above the engine. No waste-gate or BOV either, had to be very careful warming that up and idling before shutdown. Is the EB perfected enough? I still let my 2.7 idle awhile!
Maverick2022XL
name
hinterlands
100%
Just my .02
Well there is no free lunch especially with intake mods. Whether you use a high flow filter or replace it with a " cold air" intake. You will see a small bump in performance from the extra airflow but that small bump also will shorten the lifespan of your engine. That extra airflow comes with extra particulate. That extra particulate is what destroys your engine through wear quicker. Oil filters usually filter up to 20 microns this particulate is smaller than that usually as low if not lower than 5 microns.
To your point about low 11s run times, if it is a track truck then engine lifespan and wear is not going to be your main concern. Intake mods are a valid upgrade for the application. Daily driver no by itself, the trade off is not worth it.
This is probably the best explanation I found when determining if I wanted to change mine
Mudduck
JD
Utah
Thank you for the knowledge and taking time to reply in length!
I understand it can shorten engine life. For me, this is a fun truck. I do enjoy putting miles on it and giving it the beans. When my crosstrek got hit by a deer, I paid for this Mav in full with the insurance check. My plans are to have fun with it, and when the time comes, I will build up a motor and do the 2.3 turbo swap. I do run a pre filter on the SB as well, not sure if its helping, but mostly im not worried about it as I have too many cars as it is. I guess I am self inducing a new project at this point?
Mudduck
JD
Utah
I think My buddy paid $1,200.00 for His Focus RS downpipe!!
Circuit werks has a catless version for 399.00. Its tempting since it doesnt cause a CEL and there are no inspections in Texas now. (maybe in specific counties there are?) I could sell the SW Down pipe, buy the Circuit werks and maybe have 5-600 sheckles left to go towards a Cry-02 halo and set up for the Intercooler? I havent seen that yet on a Maverick.
