Mav248
2025 Mav XL
First post ever. Please be kind.
Proceed at your own risk. Don't want to be responsible for anything.
I’ll try to be quick. Through a combination of watching videos on how to add sound deadening materials (shows you how to take off the door trim), looking at ebay door wiring harness parts for colors of the actuator wire, and lots of elbow grease, I have managed to get the power locks installed on the tailgate of my 2025 Maverick XL Hybrid.
I don't know if a solution has been posted. For the past week, I have not found anything.
I don’t know the order of how each picture will show up in the feed. I used the passenger rear door since I wanted a door with as few wires as possible.
***** See Post #8 for updated instructions *****
***** The instructions immediately below include the work performed to identify the necessary wires *****
1. Remove the door trim. Watch a video on how to install sound deadening to see how the door trim is removed. The only additional advice is that there is a screw behind the tiny reflector (about 8:30pm, if you think of the door as a clock). See attached picture with highlights.
2. Mark the two wires on the inside wiring harness. White/Brown and Green/Brown. The wires are exactly 3pm and 9pm.
I actually unplugged the wire going to the latch assembly and performed a continuity test to verify the two wires.
3. Take off some interior trim to route the wire to the back door lock actuator. Not shown but I used inline wago connectors and plenty of electrical tape.
Also, took some pictures of the power window cover to show you the contact points and where to use the trim tool / screwdriver.
Enjoy !!
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Actuator Wire 1
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Actuator Wire 2.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Inside View.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Left Door.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Power Windows 1.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Power Windows 2.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Power Windows 3
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Test Setup.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Wire 1
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Wire 2
uga
SE USA
2026 Ford Maverick XLT
You would think the wires needed would be up above the spare tire, that was the location for 2022-2024 XL's.
But hey, great job....................................
rpt51
Rob
North Providence, RI
2025 Maverick XL
I am very appreciative and also terrified. I assume those wires go to the tailgate lock actuator.?
rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
Everyone is trying to find that connection, and it's their somewhere cause the upper trim levels have locking tailgates with actuator. But this is a guaranteed work around for now. I bet it was a pain though.
Mav248
2025 Mav XL
For those who chose this route, it is actually fairly easy.
New instructions are below. Some pictures are below but not sure of their order shown.
1. You do not need to take off the door trim. That work was required to identify the necessary wires.
2. Take off the interior cover on the B pillar.
3. Cut and remove the black cloth tape and find the white/brown and green/brown wires. Chose your preferred wire splicer and splice in both wires. VERY IMPORTANT. Test your power lock actuator before you route the wires.
4. Once testing is successful, then route the wires back to the tailgate.
5. Buy a generic Ford 2 wire connector as parts to connect to the power lock actuator. I built a connector from scratch. See picture.
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Wire Connector.JPG
Ford Maverick Installed Power Locks on Tailgate of 2025 Maverick XL Inside View - v2.JPG
NoVaJimmy
KCMO
Lexus GX 460
Enjoy !!
Dude, you went way too far. On my XL there was already power in the harness above the spare tire and I just had to buy the tailgate harness from an XLT and the actuator.
Waterick
Laurens county SC
You are talking about a '25 MY? Understand they're different.
Mav248
2025 Mav XL
Yes, generally 2025 model year lower trim Mavericks do not have the necessary wiring harness. The new 2025 wiring harness is for the reverse camera only.
There isn't much in terms of wiring that goes to the back (tailgate area). So far, no one with an officially installed power lock liftgate has posted their wiring harness from a 2025 model year.
NoVaJimmy
KCMO
Lexus GX 460
So Ford diluted the Maverick even more for 2025.....and raised the price, again. Wish all these savings could help boost the stock price (I have 6800 shares), too bad they're spending all the savings on recalls and half shaft replacements
Waterick
Laurens county SC
And 12 volt batteries!😁
rpt51
Rob
2025 Maverick XL
Hi, Can you tell me the part numbers?
