Installed AutoStop Eliminator
Dun4791
Vincent
Tennessee
Chevy,dodge, ford,vw,honda
Hard to believe people pay $100 for the thrill of wasting gas at red lights.
I already purchased this in the hopes of eventually getting my maverick delivered.
Sign me up, I’ll gladly pay the 100 for the thrill of wasting gas at red lights to not stop a turbo from being cooled when hot at a stop light.
Absolute worst thing you can do with a turbo engine is turn it off and on frequently, in my mind.
Sign me up!
FakeCowboy
Mid Atlantic
2016 Subaru WRX
Sign me up!
This is pretty old school thinking. Most modern turbochargers like the borg warner in the ecoboost are a) water cooled, the ecoboost even has an auxiliary electric water pump pushing coolant through the system and turbo to remove heat even when the car is not running, like during an auto stop situation and b) most modern turbos like the borg warner unit in the 2.0 ecoboost use ball bearings on the shaft and don't primarily rely on oil for complete lubrication and cooling. When you shut down your ecoboost the coolant is stull running through the system via that electric pump so the coolant is really bleeding away the heat, not your oil and you don't have to worry about the oil coking up and baking in.
Dun4791
Vincent
Tennessee
Yep the electric water pump helps to cool the turbo when it shuts off but I’ll still subscribe to wanting my turbo to have oil pressure/cooling.
Like I said, sign me up, you do you.
FakeCowboy
Mid Atlantic
2016 Subaru WRX
Just putting this info out there so people don't think that there could be a problem with the start stop system damaging their turbo and as a result they might think they need to spend a ridiculous amount of money on something they can take 2 seconds of their time to do manually if they want to but don't need to do.
Jwhisl
Tulsa
2014 f150
I drove a loaner Subaru for 3 months and put nearly 5k miles on it. The dash had a tracker for how much gas was actually saved during that time. It was less that 1 gallon. Idling for an extra couple minutes on your daily commute is not wasting as much gas as it would seem. Totally useless feature.
wyouger
Williard
2011 Ranger
What is the advantage of turning off the auto stop?
teh603
Coastal Texas
'15 Subaru Outback, '09 Honda Fit
Having driven vehicles that would hard start or have starter wiring issues? It's about not having to worry about whether or not it's going to leave me stranded, or wasting a whole green light cranking.
I get that we're talking new cars, but they won't be new forever.
Big Kahuna
WA
Just an update. This has been working seamlessly since install. I have literally forgotten about the button until I saw this post pop up again today. Great there is an option for this and I’m averaging around 28.3 mpg with it disabled.
Gpp
Gil
Sanford nc
2022 ford maverick
I think im going to just disconnect the wire at the battery that people talk about and call it done.i have no use for this bs along with some other things on new cars but im 71 so you can understand why.🤪
Exiwolf
Exiwolf
Serge
Thanks for your post! Did you have an easy time removing the connector on the back side of the DLC plug? I cant seem to pull it out.
Yes it's just a push tab , may need a pick to do it if hard plus wiggle it a bit at same time .
dddinstructor
Hiram
Honolulu, Hawaii
XLT FWD, 2.0L Ecoboost Engine, 8-spd Automatic
For those of you installing the device, use a a small adjustable wrench to help you "wiggle" the plug out. Try not to disturb the wires.
Motorjunkie
Hermitage, Pa.
73 vette, 71Fiat 850, 91 Mercedes 500SL, 2001 F150
Sign me up!
You are correct. The turbos get so hot that the oil will start to coke and in hotter climates could give problems eventually. I have personally seen this on airplanes when the pilot comes in hot, taxis to park and immediately shuts the engines down without idling for a time to cool the turbos.
