- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Had some fun in Sport mode getting some logs.You say the engine is running so I'm guess some of the power is coming from generator/motor being turned by the engine and the rest of the power is coming from the battery. The two currents get combined and sent to the traction motor. The #6 wire only has to carry the current from the battery. Not the current from the generator/motor.
I rethought about your comment about the over 150A is likely what's sent to the traction motor.
No - that has it's own PID reading, the motor. RPM, Torq, elec.
This reading is for battery current.
And I'm getting the idea Forscan has it correct, when looking at torque readings combined with motor amps and battery current and SOC recharge rate as engine recharges battery.
1% increase in SOC 3960 kW per second (instead if 1.1 kWh battery) is 39.6, pretty close to that 32kW limit. If the SOC % is based on full range of battery despite only 30-70 being used really.
I'm going to time that 1% tick increasing see if that makes sense. Should take about 12 sec to increase 10% for the SOC with engine running at idle providing max amps to battery, if it is.
Considering the system Battery Charge Power Limit is 32kW, which is 145A, brief spikes up to 150 probably not out of the question, if it stayed up there is when the system probably calls for engine braking mode, or some failsafe.
Considering the system Battery Discharge Power Limit is 27kW, which is 123A - fits the logs both directions.
27kW reduced slightly for DC to AC 3 phase, means with 94kW motor only getting 27kW from battery max - indeed there is room for more from the engine assisting.
