Hybrid mileage seems broken, possible nerf incoming?
MostlySafeBear
San Francisco, CA
(Eventually) a Ford Truck
NormalPerson
New York
Maverick Hybrid FE
What percentage of your drive was city?
It was mostly highway but i have a big hilli drive down to start my trip and charge up the battery. I then coast/battery only as long as possible. Drive bak up the hill is closer to 38-40 mpg for the trip. Still fantastic on average.
My morning drive mileage is just insane.
I have a 39 mile trip I do occasionally that's about 220 feet lower altitude which about 1/2 time I can get 60-61.7 mpg... It is mostly 45-60 mph. But the return trip is usually 37-40 mpg usually done mid afternoon when hotter and the slopes are such that the ice is used over a longer time span.
Benilla
Edmonton
Is the weather cooling down? I know heat has a negative impact on MPG as well as needing a/c
FAN2PLAYER
Zac
Lancaster, PA
22 Ford Maverick
My commute to and from my office one way is 12ish miles (small hills but mostly flat 35MPH zones, outside of the city I work in) and I'm averaging 52 mpg with my Hybrid Mav.
Clarkdonbran
Almost!
Ford Maverick Hybrid mileage seems broken, possible nerf incoming? 89B10E56-E3B1-4158-B7E7-374A95894C01
gorignak
Western SD
2022 Ford Maverick XLT Hybrid
It's easy to get short trips with good MPG. People who live on a mountain and drive down to the valley might be able to do all electric on the way down, but the way back up will more than offset that.
Ford Maverick Hybrid mileage seems broken, possible nerf incoming? 100 MPG
bentley72
Andrew
Columbus, Ohio
2026 Ford Maverick Tremor
This is the best I’ve seen on my truck. Mostly country roads drive to work. This is with climate control off and all the windows open
Ford Maverick Hybrid mileage seems broken, possible nerf incoming? F73D189C-F38F-4A26-8CAA-99241440F890
stoptothink
Utah
'17 VW jetta
My parents and in-laws both live ~25 miles from us, in totally opposite directions but both a about half highway and half streets. Parents are downhill there and uphill back, in-laws are the inverse. We're usually averaging 70-75mpg downhill and ~55mpg uphill for both of them. Wife's MWF all-highway commute (~45 miles round trip) is killing our average (currently 49.5mpg after ~3400 miles).
notliketopgun
Southwest
none, Maverick is first car
My commute is the opposite. Bottom of a valley, road goes up the grade, then workplace well after that. I tend to get 30-40 MPG on the way there depending on the battery and power, and then anywhere from 50-70 MPG on the way back. So more realistically 45-50 MPG total? I am very careful with throttle, try and minimize braking or stops in my route planning, and go so far as to cut the AC as well when I can. It might just be my experience but the hybrid performs better in cooler weather as well.
Mach 1
Randy
Spicewood
2022 Maverick Lariat Hybrid sold 2024 mav hybrid 2018 F150 Lariat 3.5 ECO
Those are some good numbers guys.
Now just put a whole tank of fuel thru.
Ford Maverick Hybrid mileage seems broken, possible nerf incoming? 20220909_124926
Had this yesterday after 19 miles the last 1.5 or so miles was down hill so I pushed the L button at 50mph and kept needle in the charge zone to where I pulled in for pit stop after which I drove the attached 1.8 miles
Ford Maverick Hybrid mileage seems broken, possible nerf incoming? IMG_20220912_161756
Mach 1
Randy
Spicewood
Dang makin You are really getting that FE.
Dont we wish we could do a whole tank at those numbers, 1200m tank, yes.
