rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
Well thanks to @HeyBales and @Mavster Mechanic I have gone down a rabbit hole with the whole 12v battery issues in the Hybrids. Thanks guys! LOL
So I will start off with an old ICE and a 12v battery to help educate anyone that needs it. That setup typically consists of a 12v battery that will power lights, radio, starter, etc. until the engine is started. At this point in time the alternator is supposed to take over powering everything. The battery sitting idle not being used should read 12.6 - 12.8v typically. This goes for a standard lead acid battery or as some people call a flooded battery. It also holds true for an AGM battery (you can research batteries yourself). When the alternator takes over the battery typically reads 13.5 - 14.5 voltage because the alternator is charging the battery. The regulator on the alternator typically adjust based on what all is being used on the 12v system of the vehicle, and adjust accordingly. The idea is to charge the battery to 100% at which point the alternator will adjust the regulator to not overcharge the battery. FYI most alternators provide 1 - 50amps of charging to a 12v battery depending on the need. This is why if you don't drive much batteries die prematurely cause they never reach full 100% charging capacity.
A quick google search will tell you that 12v SLA or 12v AGM battery should be at 100% charge and avoid being drained for prolong periods to ensure the maximum life of the battery. If you look at standard battery chargers they go from 1 amp - 75 amps. 1 amp being a trickle charger and 75 amp being a very fast charger. (you will see why I bring this up momentarily).
So Ford has stated that the deep sleep issues on the Hybrid model Maverick is due to parasitic draw and needing revised software. Which don't get me wrong, I think that is one part of the problem for sure. Two very known software updates are the ACCM update and the ABS update that is supposed to resolve the deep sleep battery issues everyone is having. However, none of these actually fixed the problem as you can search forums and also FB groups and see tons of 12v battery issues on the 22-25 Mavericks. (I am assuming nothing has changed on the 26, but I guess we will see).
Ford's initial fix before software upgrades was moving from an SLA battery to AGM battery, but that didn't fix anything because essentially these batteries both work the same. The AGM has slightly better stats and reserve time. Many people saw this fix and decided to upgrade to a bigger AGM thinking that this would solve the problem. Keep in mind the thought was the parasitic draw was the problem, and by going to a bigger AGM essentially they were buying more reserve time on the battery. A noble train of thought and a good idea, but it literally isn't solving the problem to this date.
Another train of thought was to use Forscan and increase the maximum charge setting of the 12v from 80% to 95%, why not change it to 100%? I have no idea everyone's train of thought on this, but some users reported this fixed their problem. There was never any real testing that showed or that I saw anywhere that confirms this actually does anything to fix the problem.
Now fast forward to @Mavster Mechanic findings. This one threw me for a loop until I started testing. There is a whole thread with lots of good reading material if you want to go down this rabbit hole. He is way more versed and way more knowledgeable in this matter and I suggest you read his findings. https://www.mavericktruckclub.com/forum/threads/hybrid-12v-battery-mystery-solved.81553/
I will try to summarize the findings. The 12v SLA battery will charge to 85% and a 12v AGM battery will charge to 92% in the Hybrid. At this point and time some programing in the vehicle tells the DC/DC converter to stop charging the battery and actually the 12v battery starts draining at this point and time. I don't mean draining naturally, I mean the vehicle starts draining the battery on purpose. However, if you do one of these things you can make the vehicle start charging the battery again until the battery hits full charge of 100%. (1. turn on the headlights, 2. turn on the parking lights, 3. turn the hvac fan to 6 or 7 speed, 4. plug in trailer lights). If you do one of these four things, it doesn't matter which one of the four methods, the vehicle turns the charging back on to the 12v and will actually let the 12v charge to 100%. Now keep in mind if you charge the battery to 100% the minute you start the vehicle again it will go into drain mode again because it's over the 85% for SLA or 92% for AGM.
Now while I will agree with parasitic draw being an issue that will drain the 12v battery, I also believe not allowing the 12v battery to be at 100% more times than not also contribute to a battery failing prematurely. Reading all the forums and FB posts you will see it doesn't matter if it is SLA, AGM, or even a bigger battery these batteries are failing prematurely because of the programming of how it charges mixed with parasitic draw. The people that aren't having these problems with theirs, I wonder how many of them pull trailers, drive a lot a night, have the ac or heater on high a lot, or turn their parking lights on to be seen in traffic?
Think about it like this, your battery is only 80% charged will typically read 12.5 volts while a battery at 100% reads 12.6-12.8. You leave the vehicle parked for a week when it's 100% charged and come back it's been drained to 80% because of parasitic draw and now the vehicle still starts. But if you leave an 80% battery for a week and because of parasitic draw it's down to 60% and won't start.
It's really perplexing to me why Ford wouldn't allow the battery to charge to 100% no matter what the conditions are if the vehicle is running, but I am not a Ford engineer. You would also think that they would want to come up with a solution to prevent class action, or loosing customers in general. Plus I can't imagine how much has been spent on this issue from Ford's perspective.
So now I will show my screen shots and try to describe what you are seeing.
12v SOC = 12 volt battery state of charge
Vehicle B battery Voltage = 12 volt battery reading in volts
Vehicle B battery Current = 12 volt battery amps (the amount of charge being sent to battery)
DCLA = DC/DC converter amp output to the 12 volt system of vehicle (this is like your alternator powering everything in the vehicle while running)
12 v battery quiescent avg = this is how much parasitic draw is while the vehicle is off
So to give you an idea my truck is a 2025 Hybrid fwd XL. It has had all the software updates by Ford including ACCM and ABS. It has an AGM battery from Ford OEM. My parasitic draw is between 12 - 18 mA which if you look up on google is outstanding for any vehicle 12 volt discharge while the engine is off.
The first picture is with my headlights on (it's daytime here) and the battery is 99% SOC, Battery voltage is 14.05v, the charging amps are 1.56A (trickle charge) and the DCLVA is 33A due to the truck's needs.
The second picture when I started my vehicle you can see the truck went into immediate discharge of the battery and headlights are off. SOC is 98%, battery voltage is 12.8v, charging amps are -8A, and the DCLVA is 40A due to the truck requiring that much to run the 12v system.
(See how the dc/dc converter is supplying more Amps, but the truck isn't charging the battery but instead it is draining the battery on purpose. Once I turned on the headlights the battery started to charge.)
Just FYI I also changed the maximum state of charge from 80% to 95% in Forscan, and this did not change anything at all to how the truck performs on charging the AGM battery.
Anyway, I thought this was good info for people out there, and if anyone wants to test theirs they know more about how to do it.
I am using Car Scanner Pro (it's like $8 for a lifetime membership)
I am using Vgate vLinker BT OBD2 scanner from Amazon
Marty
The Mavbrid is still spooky to me.
My test results will come when my
Motorcraft AGM fails.
It’s 17 months old now and I got 18,500 miles on the Odo, (Odometer)
It lives around 12.2 VDC
I peak it once a month overnight on my Noco Genius 1 @1 amp and reach 12.53 max.
I left it on for three days to desulfate it.
Peak VDC was 12.53
More than a few times I found it at 11.8 VDC before I peaked it.
The weird part, I’ve never had a sleep mode or limited service or battery saver mode anything.
Yep my Ecoboost is not a Hybrid but from what I can see it’s just as much a battery vampire when sitting as the Mavbrid.
No auto manufacturers would have allowed such problems to go this long without solving
10, 20 years ago.
Whu~Tu~Fu~ Ford !
What happened to quality Is Job One ?
Fix this.
rslilly76
rslilly76
rslilly76
Peak VDC was 12.53
10, 20 years ago.
Whu~Tu~Fu~ Ford !
Fix this.
holy cow that's your Ecoboost battery readings? I wonder what happens if you try one of the 4 methods to put it to continuously charge? 🤷🏻‍♂️
I haven't had any issues yes either the battery shows 16 months old and I have 17,400 miles
Peak VDC was 12.53
10, 20 years ago.
Whu~Tu~Fu~ Ford !
Fix this.
You have a power port Volt reader right?
Next time after you charge it, the next day - notice the volts while driving.
I'd imagine you'd see 12.8 early on as the SOC will be above higher limit, willing to discharge.
Do one of the 4 things and see what the volts change to.
Ya - doesn't tell the whole story without knowing amps - but likely it's charging instead of discharging.
I'd always wondered what the PID for cumulative discharge while running was used for - now I know. And why I won't see any Amp hours on it.
samspritzer
Sam
Buffalo NY
2019 CRV
I just realized you have an XL and I have a Lariat. Even with the years difference, they are still two completely different beasts. If you really want to deep dive into the issue, start by listing options among the different platforms. Eliminate matches...then focus on those that don't. If one feature behaves differently then you'll have a rabbit hole to start with. From my experience, I am betting that there is a difference in the programming logic that none of us can see.
Why do you think there must be a difference, likely completely different?
It's been shown from a 22 spec'd with SLA and replaced to an AGM, to a 25 spec'd with AGM - the strategy is the same, even if the levels are a tad different. (7% SOC difference SLA & AGM).
What's unknown exactly is how far gone (how low a SOC%), does the discovered fix no longer help with.
Throw in some bad quality battery differences.
Throw in some intermittent parasitic drain problems not effecting everyone.
Throw in some long drivers benefiting from longer float charges.
This thread wasn't really about trying to dig into the issue - it was about stating the solution to the observed issue that all trims have reported from all years.
Well - a different solution than a regular charging routine, like if you do drive enough.
samspritzer
Sam
Buffalo NY
2019 CRV
Does the XL have heated power mirrors? Sliding back glass window? If not, these would be 2 examples.
rslilly76
rslilly76
rslilly76
You do know that the trim levels haven't played a part in the various battery issues or who experiences it, right? As far as if you want to know if yours behaves any different all you have to do is try it yourself and give us the results of your findings. The various things you have stated extra on your vehicle will likely only increase the DCLVA value due to the truck needing more 12v usage while using them. I doubt very seriously the charging scheme changes at all.
rslilly76
rslilly76
rslilly76
you said yours is forscan lite, right?
Mareys
Mary
2022 Maverick Hybrid XL Area 51
Thanks to all that are Deep diving into Hybrid 12v battery issues. It is constantly on my mind as i have had many NO starts and 4 batteries in 2 years. I take every idea to heart and my son jokes that my truck rules my life (never driving less than 20min every time i start the truck etc) Thanks again i dont understand most of it but i do make any changes and suggestions that have all this research behind it and hopes that FORD figures it out sooner than later!
TheRealEman
Eric
Maine
2024 Ford Maverick Lariat FWD
Good research but this gets over my (‘24 Lariat hybrid) head pretty quickly. My dealer replaced the original battery with a Motorcraft AGM at no charge six months ago. No problem since then. BUT, thanks to you guys I know to insist on software stuff if/when they resurface.
samspritzer
Sam
Buffalo NY
2019 CRV
Maybe I wasn't clear enough. We don't know for a fact if the trim levels matter other than there are feature differences. We still don't have a conclusion even though we have some consistent behavior observations. We are looking at what we can look at which may not be everything that we need to look at. Only Ford engineering can do that.
rslilly76
rslilly76
rslilly76
so you're incapable of testing to see if yours does the same? Lol
the features aren't going to change their charging scheme
Marty
All these so called or claimed fixes forum members do and talk about as far as I can tell have fixed nothing.
