Husky Hood Bug Deflector?
Jah.
Jah.
Central Florida
Amazing second photo! And this is the husky brand deflector?
No . it's a bugflector . bought about 3 years ago . I had to modify both center mounting holes . Second picture was taken on Blue Ridge Parkway a couple of falls ago .
Rileyotta
Riley
Edmonton
From my thread: Husky Liners Hood Bug Shield Installation with the Black Appearance Package
Side view
https://cdn.mavericktruckclub.com/attachments/216/216733-
Front view
[IMG]https://cdn.mavericktruckclub.com/attachments/216/216732-5492c1de96b8217bd0e2fc382abce4ab.webp
So does the rubber seal just not get secured to the hood in the four spots used to attach the deflector, or am I missing something?
Rileyotta
Riley
Edmonton
I got mine last week. Perfect fit. I like that it does not touch your paint.
Ford Maverick Husky Hood Bug Deflector? {filename}
On the four install points of the deflector; those spots of the rubber seal no longer attach to the hood at all, since they are replaced for the mounting screws, is that correct?
Deleted member 42620
Guest
I'm not sure what rubber seals you are referring to but nothing attaches to the outside of the hood (except for the little stick on bumpers.) Everything connects on the inside of the hood onto predrilled holes with the supplied mounting screws. I'm not sure if these photos help but the mounting screws are under the weather stripping.
Ford Maverick Husky Hood Bug Deflector? IMG_6440
Ford Maverick Husky Hood Bug Deflector? IMG_6441
Rileyotta
Riley
Edmonton
Did you have to remove the light blue factory clips from the holes that the supplied mounting screws will occupy? In those places, is the hood seal itself no longer attached the way it was using the original light blue clips?
Rileyotta
Riley
Edmonton
The rubber seal I’m referring to is just the hood seal itself.
I just installed mine quickly in a parking lot, and from the best I can assume, the hood seal just isn’t held completely in place where the original mounting clips had to be replaced by the supplied mounting screws.
Guest
Correct. You remove the blue clips and in those holes go the mounting screws. You no longer use those clips but additional ones hold the hood seal in place
Rileyotta
Riley
Edmonton
Additional ones as in the remaining/existing blue clips?
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
Thank you very much for your patience and for the clarification, I do appreciate it.
I think I have successfully installed mine!
Looks good. :cool:
