- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
When it is spun up it ends up at idle RPM about 1500 for couple seconds before fired up to provide torque, also starting around 1500. After your next morning start you can hear that idle by manually starting engine with a pedal press.I think your missing my point. Regardless if it starts at 15 or 25 mph that's quite a difference from starting a car at idle. I don't really pay that close attention when the engine springs to life but I know it's not when I start it first thing in the a.m. and it starts at a higher rpm than I would typically cold start a vehicle. Just saying if there's no mechanism to circulate the oil in that condition it would cause more wear on the engine.
As it's been known for years doesn't take many seconds to get full coverage for oil, it's the taking it easy until warmup that matters more - why the advice to idle until warm is no longer given - get going calmly to warm up faster.
Same advice applies.
And actually there would be a big difference between being brought on @ 10% load and almost full load.
Hence my fact sharing.
