How long should I let it idle?
SpaceCowboy
2022 Ford Maverick Cactus Gray
Good for you. Here’s a doggie biscuit for your contributions.
A simple search will tell you the answer. It's ok to be wrong. Everybody learns something new.
5W-30 is a common multi-grade motor oil viscosity rating defined by the Society of Automotive Engineers (SAE). It describes how the oil flows (its thickness or viscosity) at different temperatures.
Here's the breakdown:
  • 5W — The "5" before the "W" (which stands for Winter) indicates the oil's viscosity (flow behavior) in cold temperatures. A lower number means the oil stays thinner (flows more easily) when the engine is cold, such as during startup in winter or cooler conditions. This provides better protection and easier starting in cold weather compared to higher "W" numbers (like 10W or 15W).
  • 30 — The number after the dash shows the oil's viscosity at high operating temperatures (typically measured around 100°C / 212°F, when the engine is fully warmed up). A higher number means the oil stays thicker at hot temperatures, helping maintain a protective film between engine parts under heat and load.
In short: 5W-30 is a versatile "all-season" oil that behaves like a thin 5-weight oil in cold conditions (good flow for quick lubrication on startup) but thickens to a 30-weight oil when hot (good protection at normal engine running temps).
This balance is why 5W-30 is one of the most widely recommended and used grades for many modern gasoline and light-duty diesel engines in a wide range of climates. Always check your vehicle's owner's manual for the exact recommended grade, as manufacturers specify what works best for your engine's design, tolerances, and performance needs.
Pointyears
Richard
South Central PA
2025 Maverick Lariat, 2018 Mustang convertible, 2012 Harley Softail, 2024 Vita
I decided to ask GPT5:
Is letting a car in a moderate climate (Florida) warm up for 15 minutes to get the oil flowing throughout the engine a worthwhile practice?
> Short answer: No. In Florida’s moderate climate, idling a modern, fuel‑injected
> car for 15 minutes to “get the oil flowing” is unnecessary and
> counterproductive.
> Key points:
> - Oil flow is near-instant: The oil pump builds pressure and circulates oil
> within a few seconds of startup. You don’t need minutes of idling for
> lubrication.
> - Best practice: Start the engine, wait about 10–30 seconds, then drive off
> gently. Avoid heavy throttle and high RPM until the engine is at normal
> temperature (usually a few minutes of light driving).
> - Idling is worse for the car and wallet: It warms the engine more slowly,
> wastes fuel, increases emissions, and can promote fuel dilution and moisture
> buildup in the oil and exhaust—especially unhelpful in humid climates.
> - Exceptions:
> - Clearing fogged windows or getting cabin comfort: a brief idle is fine.
> - Older carbureted cars or some diesels may need a minute or two to run
> smoothly.
> - After hard driving in a turbo car, a short cooldown idle (30–60 seconds)
> before shutoff can help.
> Bottom line: In Florida, skip the 15‑minute warm-up. Start, wait briefly, then
> drive gently. Use the oil grade specified in your owner’s manual.
Carlitos_92
> counterproductive.
> Key points:
> lubrication.
> - Exceptions:
> smoothly.
The original question was about idling the engine before shutdown, not before taking off.
And 15 minutes is a ridiculous amount of time to even ask about anyway. I'm surprised the AI didn't give you a sarcastic response. 🤷‍♂️
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
Magical thinking.
lm126027
Larry
Central MA
2024 EB
I do like my Maverick and it is the first vehicle I have owned with a turbo. My question is how long should I let it idle after returning home from work, doing errands or whatever it was as I heard different answers as to how long it should be. I have heard 30 seconds. one minute and up to five minutes to let the turbo cool down some before shutting the engine off. I usually wait at least 30 seconds if not longer before I shut the engine off.
Not my 1st turbo (had both a Subaru and a Australian Mercury Capri). Can't remember on the Subaru whether they recommended the idle, but the Capri did say to let it idle before shutting down if you were pushing it. Pain in the ass when you are on the highway and stop for gas. No such requirement for the Mav.
