How do you determine tongue weight?
dlhort1955
Milwaukee
Maverick FX4
I have a 16 foot utility trailer to put my old car in. I also have an FX4 so I can tow 4000 pounds. What is the best way to determine the tongue weight so I have the car held down in the right place on the trailer? Thank you.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Unless your trailer was home-built, you should have a sticker showing the trailer empty and fully loaded weights. Your tongue weight should be about 10% of what you're hauling, including the trailer itself. If you're unsure of how much you're hauling, go through either a roadside inspection station or maybe a garbage dump where they weigh you.
Redline
Upstate, NY
A car plus a 16' trailer must be over 4000 lbs, no? Even with the 4k tow package, that seems like a lot for the Maverick.
LSchicago
Lloyd
IL
Depending on the car. If it's the Model T speedster the OP has as a profile pic, it should be less than 1,500 pounds.
BlueSpec1
Gene
Measure the Tongue Weight.
Hopkins Medical Products EZ Carry 550LB Digital Scale
Fastway SIMPLE WEIGH Tongue Weight Scale
Sherline LM 1000 - Trailer Tongue Weight Scale - 1000LB
Notes: • Combined weight of vehicle and trailer cannot exceed listed GCWR.
• Do not exceed the Maximum Loaded Trailer Weight listed.
• Maverick calculated with SAE J2807 ® method.
Ford Maverick How do you determine tongue weight? Maverick Receiver Hitch Tongue 400 lbs Ford Maverick How do you determine tongue weight? Maverick Maximum Loaded Trailer Weight
dlhort1955
dlhort1955
Milwaukee
Maverick FX4
The car is a 1924 Model T speedster. You see it in my Avatar. Weighs about 1500 lbs. Two sheets of plywood on top of a chassis.
The Real Maverick
Jack
With that small car, have 2 wheels forward of the trailer axle(s) and two behind and you'll be in decent shape. Put heavier (engine?) end forward.
Also you can tell if it's grossly too much forward if your Maverick squats a lot.
With 300-400 pounds on the hitch point the truck should be about level. Squat should not be noticeable to the casual passer-by.
Derwood
Derwood
Buick and Kia
You can buy a hitch with a tongue weight gauge built in.
Decayed
yes
a car
Did they make 4k towing a requirement for FX4? It used to be separate at least it was for '22. You may want to dig into that a bit more unless someone else can chime in.
Derwood
Derwood
Buick and Kia
Sure can.
But unless you do something really unusual, you're not going to need it.
Yep. As long as one knows the weight of the trailer being pulled staying under the towing rating of the vehicle and it sits relatively level when hooked up one is usually good to go.
SVTRIDE
SE Michigan
2024 XLT Maverick
