How do I know if my battery needs to be desulfated... symptoms....
Chopperbobc
WI
2023 maverick xl
What percent state of charge and for how long before the battery sufates.... example 50 present, 30 percent 10 days....ect
https://www.batteryuniversity.com/article/bu-804b-sulfation-and-how-to-prevent-it/
There are two types of sulfation: reversible (or soft sulfation), and permanent (or hard sulfation). If a battery is serviced early, reversible sulfation can often be corrected by applying an overcharge to an already fully charged battery in the form of a regulated current of about 200mA. The battery terminal voltage is allowed to rise to between 2.50 and 2.66V/cell (15 and 16V on a 12V mono block) for about 24 hours. Increasing the battery temperature to 50–60°C (122–140°F) during the corrective service further helps in dissolving the crystals.
Permanent sulfation sets in when the battery has been in a low state-of-charge for weeks or months. At this stage, no form of restoration seems possible; however, the recovery yield is not fully understood. To everyone’s amazement, new lead acid batteries can often be fully restored after dwelling in a low-voltage condition for many weeks. Other factors may play a role.
A subtle indication whether lead acid can be recovered or not is visible on the voltage discharge curve. If a fully charged battery retains a stable voltage profile on discharge, chances of reactivation are better than if the voltage drops rapidly with load.
Cherokee
And for AGM batteries the Noco Genius 1 for $30 at Walmart de sulfates automatically while charging.
It’s called ‘Pulse’ charging I think,
Old/new tech, the automatic desulfate chargers have been around about twenty years now.
