Horn going off early morning
Truck2
jeff
usa
toyota highlander hybrid
So, this morning the horn decided to start blaring for no reason at all and I didn't see anybody outside trying to break into the truck. When I called the dealer they said it could be because the battery is low on the key flob. Does that sound right to you?
Maverick Country Club
Larry
2025 Maverick Lariat Ruby Red Metallic Black Appearance Package
With 2 seconds of thought… no.
Kenv24
Ken
2024 XLT
The alarm went off on my F-250 one night. Gated yard...no one around for sure. I go out and it was a moth flying around inside setting off the motion sensor. Showed on my Ford Pass app that horn was honking. :cool:
EffNo50
Central California
No interior motion sensors on the Maverick. If you add the Perimeter Plus module then a bump can set it off (adjustable) and it will also send the notification to the Ford Pass app.
Kenv24
Ken
2024 XLT
Yeah, I wasn’t sure if it was a lariat thing or not. I’ve only got an XLT so I didn’t know.
EffNo50
Central California
I have a '24 Lariat, it doesn't have interior motion sensors. There was a thread on here about tracking them down as there is a mention of them in the manual.
Silly Willy
Lawrence
West Virginia
23 Mav.
I've had the wind set off an alarm on a car I had a few years ago.
REMUB40
Fredericksburg, VA
2018 Honda CRV
If the fob was in your pocket, the sensitive panic button may have been hit. Happened to me a couple times.
EffNo50
Central California
THIS! It has happened to many users. I keep mine in a cover, so removing the panic button from the fob was the easiest route for me. Easily snaps out, and can be snapped back in (provided you don't lose it) should you wish to restore to original.
Robot-Wrangler
Kentucky
Yeah, me too!
Ford Maverick Horn going off early morning 20251117_174340
ken h
Kenneth
Goldendale, WA
I noticed that every once in a while, when I open the door behind the driver it will beep. Car is unlocked, engine is off. There might be other times, but it is rare enough that I don’t remember. Usually happens when it is embarrassing..
