Hood deflector
Tunerman570
Michael / Mike
Menifee,California
2024 Maverick XLT
I wanted to protect my hood from roost damage and I purchased the ford deflector. I tried hard to get it on straight but no luck. Do you know of any way to straighten it? I was in 104* yesterday and tried, but it’s stuck.
Clarkdonbran
Do you get a lot of cocks on your hood?! 😂
Picture please. It helps.
Is this the type that sticks directly to the hood. Is it the type that bolts on to the hood???
If it is the stick on Ford Aeroskin hood protection. Sadly, the answer is NO. You'd have to peel it off and in the process you'll probably stretch it causing a wrinkle or bubbles when you try to reapply it and it won't stick like it originally did. You will end up having to spend another $100 and very carefully start all over.
If it is the kind of deflector that sits off of the hood. I don't know of any options to reposition it
Mike1597
Western Kentucky
2025 Maverick Lariat AWD, 2024 Mustang Mach-E, 2024 Ford Edge
Maybe warm it with a heat gun and if necessary, run fishing line like a saw behind it and slowly work it off, perhaps then you can reposition it?
That’s a great tip,I’ll give it a try. Thanks
After more than 7 years of co-owning and working in the vinyl graphics and PPF industry.
Try not to pick it up. Off the surface
Be very careful with the heat gun no pulling. Your best results may be using a friend or two with the heat gun, try to reposition by gently sliding it into place. When you're done then remove the residual adhesive.
My biggest advice is patience and take your time.
Keep us updated.
Good luck
Ford Maverick Hood deflector 20240908_094655
William Buckman
Buck
Dothan Alabama
24 Lariat Carbonized Grey
T
That's one reason why I installed EGR hood protector. It bolt/clips on. I was able to adjust the position without being stuck on with very aggressive tape.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
what pound test? Well, the post is getting all the wise cracks and I had to join in.
