Hitch and wiring install from Ford Accessories
GA Hot Pepper
Dick
Georgia
Mustang Mach E, F-150 Lariat, Toyota 4 Runner
I was searching Ford Accessories and came across the part number for the hitch assembly. Just search Ford Accessories. The bonus was, they have a listing for the wiring loom and installation instructions for the wiring of the 4 pin system. Trailer Tow wiring kit. Part # FT1Z15A416A. $125. The instructions are there also. “FOR MAVERICK” Just wanted to pass this along, since there was so much discussion about aftermarket wiring causing issues
ShadowBlack XL440
Robert
Northern Ohio
Good luck with that wiring harness, looks like the Curt would be much easier to install. The Curt is plug and play into the tail light plugs, no splicing, and just a dedicated power wire to run to the battery.
gte105u
Katy, TX
Yeah, there was an incorrect rumor you can't add a hitch. But there have been videos and posts about doing it for months. I'd do the Curt one myself if needed. Seems easier. I think UHaul is also doing them but if I was going to pay someone I would pay the dealer.
GA Hot Pepper
GA Hot Pepper
Dick
Georgia
Numerous posts have mentioned, fault codes with aftermarket wiring and will void your warranty. This and the hitch are genuine Ford Parts and can be installed by yourself or the dealer. No warranty issues.
ShadowBlack XL440
Robert
Northern Ohio
Christenhildebrandt
Christen
South Dakota
Ford Fusion
Will be interested to hear if Long McArthur and @fordvideoguy will have luck with it. Only downer is fords website makes it seem like it is almost $800 to add later on.
Bry@n
Bryan
Central NJ
23 Maverick XL, F150, Bronco
$100 when ordering and it's installed. $500 in parts after the fact and you'll need to install. Not hard but I'd only do it if I already had a truck and need the hitch. I don't think I'd change my order to get sooner and then install after the fact.
GA Hot Pepper
GA Hot Pepper
Dick
Georgia
When I posted the thread, I wasn’t thinking of cost. It would be expensive. There was so much talk about wiring issues and fault codes/warranty problems. Just wanted to put the info out there. I’m waiting on a XLT w/Lux (hitch inc)
Tom Cruise
G
Ottawa ont, Canada
Hybrid XLT 2022
My 2 cents rant here....I guess its old school thinking but any vehicle with a motor can tow/haul. So a tow hitch and a live wired connector should be mandatory on all vehicles especially if they want to call it a truck...... Anyone attach a ball to the bumper? like we used to do on pickup trucks.
JimKivi
N Calif
2023 Maverick XLT 4x4, Silverado, Mazda 3, Ranger
Instead of the factory tow hitch (deselected to avoid constraint items), on my truck with a full sized spare, I had good luck with the H Freight $29 hitch. Cutting the passenger side into the centermost of the two holes on the right side left me with steel the width of the rear bar, and four 1/2" bolts had me in business. Afterwards, I cut the cover plate to fill the hole on the left of the hitch, and used screws to replace the pop rivets on the bottom which originally held that cover plate.
Ford Maverick Hitch and wiring install from Ford Accessories hitch
JimKivi
N Calif
The cover plate is not shown here, but the positioning of the hitch with the simple rectangular cut on the right side allows the hitch to clear the full sized spare.
Ford Maverick Hitch and wiring install from Ford Accessories hitch-bumper
