Help me install audio gear into my hybrid Maverick!!
klutch14u
2025 Maverick XL
I'm determined to only remove panels ONCE and want to get everything installed right the first time. I'm asking for community help. I'm looking to add 6.5" Kicker door speakers (already have) and a powered subwoofer.
Amp/sub I'm looking at https://www.amazon.com/gp/product/B019Z3R582
I'm planning on tapping the battery/ground directly for power since it's in the rear, amp/sub will be behind the seat.
I understand you have to tap the wires to the existing speakers somehow. I've seen some say the front, others say the rear. Also, I seem to remember having to have another device (Pyle Link or Boss maybe) that makes is so the amp can actually amplify the stock head unit and remote on work correctly. I can't for the life of me find it again though. I want to avoid too much tapping or butchering factory wiring.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
Are you looking for advice or do you want one of us to stop in a start pulling apart your interior?
Aaron F
Aaron
Sterling Heights, MI
2023 Maverick Lariat Lux w/ 4k and BAP / 2025 Maverick AWD Hybrid Lariat w/ 4k
Order sound deadening and butyl rope before you pull your door panels off. Otherwise you will end up pulling them back off to chase down rattles afterwards.
Ford Maverick Help me install audio gear into my hybrid Maverick!! 20240525_091800
Ford Maverick Help me install audio gear into my hybrid Maverick!! 20240525_103652
23OxOrdered
NJ
2023 Maverick XLT - BAP and LUX package
I put a Infinity Basslink Mini in behind the back seat using the empty bracket (as no BO system) (see pic)
Tapped into rear speaker line. (see pic)
I had only trick issue had to undo Occupancy mode setting back to default "All Seats" the amp would not produce sound until back to default all seats. (see pic)
Ford Maverick Help me install audio gear into my hybrid Maverick!! 20250523_BassLinkMiniSub_mounted3
Ford Maverick Help me install audio gear into my hybrid Maverick!! 20250523_BassLinkMiniSub_mounted4
Ford Maverick Help me install audio gear into my hybrid Maverick!! 20250523_BassLinkMiniSub_mounted2
klutch14u
2025 Maverick XL
Good info, kind of thing I'm looking for. Do you think tapping the front speakers would have avoided the 'all occupancy' mode? Do you tap both wires on each side? Where did you run remote to? Nice, clean install without going overboard BTW.
