HELP - Front Side Marker Light DRL Amber Sequential Turn Signal Lamp 2 in 1 Function Feature Kit for Ford Maverick
Fender66
Scott
Charlotte NC
2025 Maverick Lariat
I got these as a present and I have no idea how to connect the wiring. They didn't come with any instructions. No wiring harness of any type.
A little help would be greatly appreciated.
Ford Maverick HELP -  Front Side Marker Light DRL Amber Sequential Turn Signal Lamp 2 in 1 Function Feature Kit for Ford Maverick Front Panel Lights
CurtisB
2023 Maverick XLT Hybrid
If the lights didn't come with a wiring harness, thats not good. If you wanted to try and splice into wiring and do it yourself, there are people who did it 3 years ago. It isn't fun and you will become frustrated. Most of the aftermarket ones available today come with instructions and wiring harnesses. I did mine (see my profile photo) and it came with a harness. Pretty much plug and play.
Check to see if yours was supposed to come with a harness of some type.
Ray_B
Ray
NJ
2025 Maverick Lariat Hybrid AWD
Ad says it comes with harness. Maybe they sent you a return. Or check the packaging. Clearly NOT Plug&Play!
Ford Maverick HELP -  Front Side Marker Light DRL Amber Sequential Turn Signal Lamp 2 in 1 Function Feature Kit for Ford Maverick 1766789065155-n6
DonG
Don
Langhorne PA
2023 Ford Maverick, 1994 Ford Bronco, 1983 Ford F350,1966 Ford F100
This is the one I used. Worked great
Ford Maverick HELP -  Front Side Marker Light DRL Amber Sequential Turn Signal Lamp 2 in 1 Function Feature Kit for Ford Maverick Screenshot_20251227_095135_Amazon Shopping
Pointyears
South Central PA
None of the side lights I've seen don't work with the 2025 Lariat. Better check that out....
Fender66
Fender66
Scott
Charlotte NC
Mission accomplished. Turn signal works but the white running light does not. It requires a third lead wire which isn't provided by the "system".
The only tricky part is pairing the wires correctly. The colors don't really mean anything. I had to match them to the adapter based on position relative to the factory connector.
Mdmac
Kansas
2023 Maverick XLT
