Heated Seats not working (less than 30 degrees outside)
smspaulding58
Zion Crossroads, VA
Ford Maverick Hybrid Lariat
Temp is below 30 degrees outside and heated seats don’t work. Anyone else have this issue?
Gullzway
OK
1968 Ford Mustang Fastback
Is the heated seat button lighting up?
Ford Maverick Heated Seats not working (less than 30 degrees outside) Screenshot_20221226-063847
The Weatherman
Dean
KY
Nope. Work perfectly in both trucks.
Mine work perfectly, matter of fact, after being on the high setting for a few minutes I have to turn them down on the lowest setting or completely off to keep my buns from being roasted. Hope ya get yours corrected. Maybe a fuse?
Joe Kelly
St Charles, Mo
1973 Triumph TR-6, 2009 Accord, 2017 Pacifica
Mine get too hot. Last week I had to put them to the lowest level then turn it off because it gets too hot.
Scott Asheville
Scott
Asheville, NC
They work like a champ. Which this 66-year-old appreciates during this cold snap. Ditto for remote start.
atomguy245
Doug
MIne too. The steering wheel gets very hot as well.
GPSMan
Many
My wheel gets almost too hot to hold at 35°F for the first 10 minutes, then it goes into some low trickle mode that maintains body temperature.
Seats are almost too hot on low at 35°.
Sometimes I'll set it to high for the first 2 minutes, then low the rest of the trip. I'm not positive high RAISES the temperature quicker but I think it does.
Anyone know if the heat settings are wattage based or duty cycle based?
MaverRick
Rick
Finally cold enough to use them down here! Worked great for me and my Wife!!
