Head lights
whitsoneric48
Eric
Kentucky
2025 Maverick
I am getting a 2025 XL Maverick this week and I would like to know if it is possible to switch out the XL head lights for the XLT head light unit since it has the led strip around it for day time running?
whitsoneric48
whitsoneric48
Eric
Kentucky
2025 Maverick
The XLT does not have the LED strip your referring to. Only the Lariat has that.
Good to know I miss saw a video then today. Ok so different trim, but same question can you put the Lariat's head light unit in a xl truck?
Brett3550
Brett
WI
Velocity Blue XL
I would wait until FORM LIGHTING comes out with their after market headlights. They look better and will be much cheaper than the Lariat headlights.
Sticks
Shawn
St. Louis
2025 electrical diagrams haven't been released to the usual third-party channels yet. The BCM will probably need to be reprogrammed, but I can't confirm if the wiring is the same. Hopefully someone with better resources can chime in.
For 22-24, they don't need any wiring changes, but they require programming changes to the BCM using Forscan to enable the DRL signature. There are multiple threads on here about that swap.
whitsoneric48
whitsoneric48
Eric
Kentucky
2025 Maverick
The Lariat headlights are perfect, they are classy without being over done. I would not own a Maverick today if it were not for those headlights on the Lariat.
Do you happen to know if you can plug and play the Lariat's lights into an Xl without having to do anything extra?
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
KEEKPO - For 2022 2023 2024 Ford Maverick w/o LED DRL Upgrade Style LED Headlights Headlamps Replacement Left+Right
https://a.co/d/hV5Ie8G
This is available for 1st. Generation, give it a little time and aftermarket will have available for the 2025's.
I have 23 xl and if I ever have a problem with mine I will buy above.
Good luck on the 25, love the new look too
bgn
WA
60-day warranty on headlights. Yikes.
TwuckHappens
Jefe
2025 Maverick Lariat
I believe the Lariats have 1 more pin than the XL/XLT connector for the DRLs but I haven't checked it out myself.
Carlitos_92
