Has anyone installed a catch can?
huwalk
Maverick XLT
What are the benefits?
ScubaSteveCanada
chatham
2024 Ranger Lariat
Catch cans collect atomized oil droplets.
I had to clean a sensor (using brake cleaner) on a Ford E350 6.8l V10. It wasn't an issue to clean the sensor. Eventually, yes, I had to replace the sensor but not sure if a catch can would've prevented that replacement. On an inline 2.5l 4 cylinder, it probably isn't necessary.
sg777
tracy
mississippi
2025 maverick tremor
I tried but my 2025 tremor wouldn’t allow room for the canister so I sent it back,
uPR makes a plug and play for the 2025 that; I;;try next
BusaD
Donald
Virginia
F150 Maverick
I have two on my truck. One on the dirty side and one for the clean side. They work well to remove oil from the intake air on a turbo direct injection 4 cylinder. It is to help prevent deposits on the intake valves. Hope that helps you understand the purpose.
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
from decades of talking to people and reading articles, I have concluded that catch-cans are a useless endeavor on modern engine systems. Perfectly cool for your 1960 F100 truck, though. Those who believe they somehow have a benefit will voraciously defend their position though, and if that placebo eases their mind, I have no problem with them installing one. Same with K&N filter on a modern vehicle (which is actually BAD for them...).
BusaD
Donald
Virginia
F150 Maverick
I think you were replying to me. Thanks for the information.
The reason for them is because the direct injection engine does not have the gasoline washing across the intake valves face. The dirty side catch can catches a lot of nasty gunk. More so in cold weather. The clean side not so much. I think it is good keep that stuff from leaving deposit on the intake valves. The 25 Mavericks have a new two stage fuel injection to address the issue. I am referring to the 2.0 ecoboost.
Tbone289
MO
What reason did the people you talked to and the articles state that it isn't beneficial for a direct injected engine?
