Guide for interior trim removal?
clavicus
I installed a front and rear camera yesterday.
I have included a few pics of the finished product. The only tools I used were two small trim tools designed to loosen the trim without scaring. You can pick them up for less than 10 bucks at any automotive store or online.
The only spot I wasn’t able to totally hide the cable was in the back passenger side corner. I think if I had stayed at it or had a second set of hands I’ld got that tucked away too.
This was done without removing any of the trim or headliner.
I was able to tuck the cable up and behind the trim as I worked my way from front back.
Won't your sliding rear glass impact that placement of the rear dashcam? I figured it should be on the other side.
The Weatherman
Dean
KY
No. The window moves the other way.
FriscoTXJoe
2022 Maverick Lariat
I admire your all's mechanical ability. Would like to do the same but just don't trust myself to do it right. When you buy a camera for the car, can you hire someone to install it?
clavicus
Ah of course you're right. I was always looking at it in the rear view mirror so I had it backwards in my mind lol
Ford Maverick Guide for interior trim removal? 1642966597926
g1zstar
NY
XL Hybrid Barebones
You should really just look into doing it yourself. You don't even have to do anything fancy if you're not comfortable. If you don't feel comfortable popping the trim out a little bit to put the wires in, you can just run it in the semi-open. A good dashcam should come with little clips meant to hold the wire and that stick to the windshield. Run the wire towards the top of the windshield then left towards the door, tuck it between the door and dashboard. Go down, head right and there should be a place to tuck the wire into beneath the steering wheel where it won't be in the way of the steering or your legs. Make your way to the usb plug and you're good. Just tuck it in all the nooks and crannies along the way. Experiment and see where the wire will stay. If you're doing the rear camera also (or even the front camera wire you can do this) put it underneath the floor liner. Just make sure near the doors it's flat and won't snag your feet or your passengers feet and you're all good.
Putting it underneath the trim just makes it look extra clean. Wiring to a fuse just frees up that usb slot. Also it does let you safely keep recording while the car is parked without killing the battery. (Some dashcams have a gforce sensor in them which will make them record if someone hits you while you're parked for example)
But at the end of the day the main use of the dashcam is still just for evidence in case of an incident. These things are very popular and are designed for people with no mechanical knowledge.
clavicus
I just finished mine today. I ran front and rear like The Weatherman and tucked up wiring just above headliner like him. I also had that small spot in the rear corner that I couldn't tuck up, but haven't tried too hard as it doesn't bother me since it's hard to see with the black behind it.
I tapped into the #2 fuse slot in the fuse panel under the glove box. It's unused, so it's a good place to tap into. I tested it with a multimeter and it is powered with ignition.
Question about your tapping into fuse #2.
So that's a 3-blade Micro3 fuse type, do you simply put in a Micro2 fuse on the appriate side for #2 load (middle is common line?) and leave the #1 load slot 'empty'? I guess you need an extra 5-amp Micro2 fuse if you're using a fuse-tap so that both fuse slots are filled, since you aren't re-using the Micro3 fuse?
EDIT: Oh the plastic housing standards for Micro2 and Micro3 don't work together. Do you use one of these one of these (two sides) or one of these (one side)
I also tested 1/2, 8/9, and 15/16 Micro3 fuses as also powered by ignition.
Otherwise it seems only #3 and #6 are the default Micro2 fuse slots that are powered on accessory/ignition.
What does "Extended Power Module" mean I wonder.
FriscoTXJoe
Thank you for the details. I really should do it, I do plenty of work on my house but something about snapping one of those fasteners or wiring it incorrectly just scares the hell out of me! Maybe I find a video showing any similar and just follow it....Come on Ford, sell more Mavericks!
IndyHavoc
Indianapolis, IN
Honda Odyssey -> '23 Maverick XLT Hybrid
Anyone have reason to remove or modify the center console at all. Or have details about what, if any, wiring is in the hollow area behind the interior available space under the armrest, and the back USB+110vac plug?
