Get navigation on the 6.5" dash display?
propp2531
Philadelphia
Maverick XLT FX-4
I'm in the same boat, APIM doesn't show up on my 2022 2.0EB XLT Lux. Doesn't seem like a cable issue (no switch on my cable).
Only the Lariat has an APIM all others do not
Deleted member 35678
Guest
Thanks. Turned on the repeater/turn by turn from first screen and Repeater(Heads up display) options, worked. Waze seems a little slower than google maps, but only tested around the block.
Mine is a 2022 Lariat Lux.
Surprised I haven't seen this mentioned on the forum, or did I miss it somewhere?
But that setting has "Navigation Disabled" in the APMI. When I do that my sync navigation is gone and the CarPlay directions don't show up either.
mar.neumann
Marcelo
Brasil
Maverick Hybrid Lariat 2024
After hours of looking at YouTube, forums, and even reinstalling the drivers to the damn thing, I am still not seeing the APIM when I plug in my OBDLink EX. My laptop has all the necessary qualifications so I'm not sure what the issue is.
However, I have been able to get the Eco Coach and speed limit signs working. But I need access to the APIM to tell it to actually send the turn-by-turn data for the IPC to display.
Hello...
Answering you and also @TrippMe
I may be wrong, but from the little knowledge I have, APIM is related to Sync 3.
It probably doesn't appear for you because your truck is Sync 2.5.
The same thing happens to me, my 2024 Maverick Lariat Hybrid (Brazil) came with Sync 2.5, so it doesn't have APIM...
Cheers
commadorebob
For a 2023 MY it'd depend on if it was optioned with the Luxury Package or not if it has Sync 3 or CTR. (2.5).
I have a MY23 Lariat Lux and it doesn't show.
Gullzway
OK
1968 Ford Mustang Fastback
Carplay doesn't work only Android Auto, on the instrument screen. My 2022 doesn't have Navigation, not that I would use it over Google Maps.
commadorebob
When you connect with FORScan and it asks if you want to reuse the profile tell it no. It'll rescan the modules and may find it then.
Yep, tried that.
