Gas Type
Doc Randie
A
NA
www.ford.com
Ford Maverick Lariat
Y’all use unleaded or premium?
bbhaag
Premium 91 octane or better.
SkeeterB
The Woodlands, TX
Both are unleaded. I use 93 when I can get it. Mileage is a bit better and George is happier.
SaintClairMaverick
Novi
Saint Clair Shores MI USA
Do i need to tune my Maverick for premium gas? Well I've been using premium since i took delivery back in November and I've just recently been getting questioned on if I've had it properly tuned for premium.
PNWMaverick
Pacific Northwest
2022 Maverick Hybrid - RIP
Owner's manual covers this.
Ecoboost; Premium 91+.
Hybrid; Regular 87+.
The Ecoboost is a high compression, direct inject, turbo charged, engine. If you use less than 91+ (per the owner's manual) you can induce knocking. Over a long period of time this is horrible for the engine. This isn't just for Ford's Ecoboost line but any engine of this type.
The hybrid engine is also rated at a high compression but it is an Atkinson cycle and has an effective lower compression ratio. As such, you can use Regular fuel in it just fine and it likely won't see any gains with Premium.
04mach146
Brad
Chevy Tahoe, dodge eco-diesel
Ford Maverick Gas Type Screenshot_20220316-190634_FordPass
04mach146
Brad
Per the owners manual 87 is what is recommended see the picture above
DeanR
colorado
Outback Tundra F250
6100 miles only 87. Well I take that back tried some premium because the stations price difference was 10 cents. I saw zero difference, won't go back unless there is a price diff like that again.
DeanR
colorado
Outback Tundra F250
The ecoboost has a WAY lower compression ratio 9.3 versus the 2.5 with 13 to 1
PNWMaverick
Pacific Northwest
The hybrid is an Atkinson cycle engine and in operation has a lower compression ratio than the "rated" number you are quoting. It is why I said, "effective lower compression." During the first part of the compression cycle the intake valve is left open.
Edit: The 2.0 is a slightly lower compression ratio than the 10.5 I thought it did.
Sjurgen
Shannon
Oregon
Chevy Spark, Toyota Prius, 1973 F100
The EcoBoosts has knock sensors, so indirectly it senses the lower or higher octane by listening to the knock sensors and adjusting the ignition timing accordingly. Low octane in the Ford Maverick EcoBoosts engine will never harm the engine, even when towing the 4K amount. The engine will compensate with timing retardation and higher engine revs.
Ozarkbeard
AFAIK, all US gas at commercial pumps is unleaded.
OP, you didn't say what vehicle you have, but if it's a Hybrid, all you need is 87 Octane, per the user manual. You might take a little time and actually read it. Lotsa helpful info in there.
