Fumoto drain plug
psuarmy
Pittsburgh
22 Maverick
Whats the point of an easier drain plug when you still have to do the hard part and drop the skidplates?
So the big skid plate doesn't have to come off, but there isn't a lot of room to work. The smaller skid plate isn't had to remove to get to the filter. Hopefully with this valve I can keep the big skid plate on and run a hose to a container and just flip a lever to drain without making a mess. My first oil change oil dripped on the top of the skid plate.
psuarmy
Pittsburgh
22 Maverick
Does that model look like it will fit better?
I am hopeful that it will, but I can't test without draining the oil. I think there will be enough room to use the plastic access panel.
olderbudwiser
Has anyone taken their Maverick Eb or Hybrid to dealer for an change.
Just had oil changed on F150 5.4L 7 quarts of Motocraft syn/blend $49. To me Im good with that. (Ford Dealer)
DCP
Tennessee
2014 Flex, 2018 Escape, 2023 Maverick XLT Hybrid
I just completed my second oil change on my Maverick Hybrid and added the Fumoto Oil Drain Valve F137N and the adapter ADP-137 (won't go on without it).
Ford Maverick Fumoto drain plug IMG_1824
Ford Maverick Fumoto drain plug IMG_1825
BoboysTruck
Virginia
F150, Focus, Juke
I did too. Another angle to show clearance if anyone is wondering.
Ford Maverick Fumoto drain plug 20220625_114910
And another pic
Ford Maverick Fumoto drain plug 20220625_114829
Starwatcher
RICHARD
Phoenix
I bought a Fumoto drain plug. The F107SX. The website says that it fits the maverick without the 1/2 inch adapter. It will fit, but extends beyond the FX4 Skid plate which makes it not a viable solution. I am assuming the felt skid plate will have the same issue.
I contacted the company and sent them some pics. They are sending me a straight F137S with 1/2 inch adapter to see if it will work, but it will be a while until I change oil again. Either way the company has been extremely helpful and pleasant to work with while I try to find a solution.
Well, if it won’t fit right without mods, I will not use it. Too bad. Looks like a good idea.
Starwatcher
RICHARD
Phoenix
I can’t buy the oil and filter much cheaper than that
Wnbasac
Louie
Calif
Honda CR-V & firebird T/A
I use this on all my vehicles , simple and sweet
Ford Maverick Fumoto drain plug CC321A08-5526-4ADF-B299-76A9E26C034C
BoboysTruck
Virginia
F150, Focus, Juke
Just did my first oil change since I installed it two months ago. My first FUMOTO drain plug and man, it's the way to go. Makes it so easy and less messy. No splashing with the hose. Still messy dropping the filter though.
Ford Maverick Fumoto drain plug 20220825_095443
Anyway, I was trying to remember what size socket I need for the drain plug. Then I realized, holy crap!!! I don't need that anymore! This is literally the only tool I need now.
Ford Maverick Fumoto drain plug 20220825_104226
psuarmy
Pittsburgh
22 Maverick
What I did with the oil filter is fold up aluminum foil and shove it behind the filter once you loosen it up. fold the foil so it drips into a catch pan. Once it is done draining take the filter off, drop it into the foil and make a mess that way. It will at least give you a little hope that you won't make a mess. Worked for me. Maybe next time I will catch it.
PortlandME
Portland, Maine
Did you also use the 137N w/ adapter?
BoboysTruck
Virginia
F150, Focus, Juke
Rflick
Ron
Granger,In
2016 Buick Encore + ordered Maverick
Thanks for your information and photos concerning the Fumoto drain valve part numbers including the extension needed. Just ordered from the manufacturer website which recommended the same product numbers. Our Maverick looks just like yours, thanks again!
  • Like
Reactions: DCP
