- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
It appears from the pictures of the tanks - they both benefit from having a hefty air space above the fuel inlet line.It seems the Hybrid & EB share the same external gas tank shell.
But how & why is the Hybrid’s tank pressurized? Are there internal pieces inside the hybrid tank taking up space? Also, is it negative or positive pressure?
And with full tank the level will rise above the inlet line.
That's an automatic block of fumes for awhile for the main tank.
The filler hose area would still have fumes - hence the canister being hooked to it.
I loaded the PIDs regarding fuel tank - there was a notice on the fuel level PID about EVAP leak check test ONLY runs between 30 -85% full.
Unlike other PIDs that state for hybrid or EB - this did not.
Makes sense - if fuel is blocking the inlet pipe, which is what the canister is connected to - can't check the whole tank. And too low, too much volume for the small pump to pull enough vacuum to confirm anything.
The why positive pressurized has been shown to reduce the amount of evap - which could become a problem with the ICE running less, therefore more time to evap.
