Front turn signal pinout at lamp connectors
fahrfrompuken
Rick
Kyle, TX
Anyone know the pinout for the front turn signals? Going to tap into these wires for my new light strips.
I'll bet the black wires are ground...
1st pic is Driver's side.
2nd pic is passenger side.
Ford Maverick Front turn signal pinout at lamp connectors 20230101_162807
Ford Maverick Front turn signal pinout at lamp connectors 20230101_162758
NoVaJimmy
KCMO
Lexus GX 460
fahrfrompuken
Rick
Kyle, TX
Thank you so much!
garryjohnson
Garry
Pensacola, FL
Ford Maverick XLT FX4 Atlas Blue
fahrfrompuken
Rick
Kyle, TX
Got the strip lights installed. Don't work unless I unplug the OEM turn signals. Too much load I think. Hopefully they will work with my Lasfit switchback turn signals.
Ford Maverick Front turn signal pinout at lamp connectors 20230102_210859
fossil
ernie
ohio
if you would be so kind, what is the power draw, amps or watts?
fahrfrompuken
Rick
Kyle, TX
Not sure of the specs. These are eBay specials.
luciusxlt
Alexis
miami
2022 for maverick XLT
hi, do you have the diagram on the headlight pin for the low , high beam and DRL?
thank you
gp1200x
Paul
NY
GT500,C8-Z51, 2023 Lariat Lux 4K Co360
What LED module did you buy on Ebay? I may try to add these too.
numike
mike
car
after 8/10 all the lasfit bulbs burned out
SKIP lasfit!
Tech Tye
Ken
Kentucky
2023 Maverick
Same here, LAS QUITS. Went with MAXGTRS. My current setup is the amber only as it mates very well with the reflector lens, gives the most uniform output. I couldn’t get the switchback to function on the white side. I tested the bulb on the bench and it works, however the amber give a distorted pattern. I put the straight amber back in . It’s a 7440 base. I did modify my lamp socket so I can put any 7440/7443 style bulb in.
Ford Maverick Front turn signal pinout at lamp connectors IMG_6349
Ford Maverick Front turn signal pinout at lamp connectors IMG_6348
