Front license plate
Fred Leeson
Fred
Portland OR
2024 Maverick XL
Where the heck does it go? Couldn't there be a simple place for it? Or am I blind?
Carlitos_92
Fred Leeson
Fred
Portland OR
2024 Maverick XL
Upon closer inspection, I found two indentations where the screws presumably would go. Alas, they were not a perfect fit with my plate. Easy to drill the needed holes.
todd92
It attaches with plastic rivets, not screws.
oysterville
Oregon
2024 Maverick Lariat
Dealership should provide the mounting bracket. Reach out to your dealer.
GotKT
2023 Maverick
My install without drilling into the front bumper.
Ford Maverick Front license plate IMG_9061
STARCOMMTREY1
Trey
Boligee, AL
Not for nothing and it will likely never hurt, but that does cover part of your cooling system.
Duke Nukm2001
Larry
2024 Atlas Blue Metallic Maverick XLT (aka "Brett Maverick").
I purchased mine and bought two (2) 6.5mm drill bits (needed to make the holes) , and a "Plastic" Pop-rivet" gun 6.5mm Metric M35 Cobalt Steel Extremely Heat Resistant Twist Drill Bit of 2pcs with Straight Shank to Cut Through Hard Metals Such as Stainless Steel and Cast Iron, 5% Cobalt M35 Grade HSS-CO - Amazon.com (rivets were too big in diameter for my standard pop-rivet gun). Amazon.com: Keadic 132 Pcs 10 Sizes Plastic Rivet Assortment Kit with Poly Rivet Gun and Free Rivet Puller Remover for Automotive and More : Automotive (pop-rivet gun kit from Amazon was cheaper than the one from Lowes) from Amazon and followed the directions in the box (that the plate holder came with). Hope that this helps. Larry.
Jimmyland
Pennsauken, NJ
2023 Ford Maverick
Dealership should put this on for you. Had mine done there on pickup when my plates came in. Too all of 10 minutes to put on.
rrcobler
Randy
Fox River Grove IL
2022 Maverick LARIAT
Forget the front license plate. Even though it is required in Illinois I have left it off with no problem. I've notice lots of TESLA's with no front plate (which would look really ugly if installed) and I think the local police and sheriffs departments have decided to let the "no front license plate" slide.
aflacks
Andy
Baltimore
XLT
I live in Maryland and they won’t stop you for no front plate, but if I park in D.C. the folks there will ticket you for no front MD plate-Go Figure!
Exranger
Northern California
I agree with you. Mine was “lost” due to earlier supply chain constraints. Now it is back ordered and may not arrive😉
Ford Maverick Front license plate IMG_0443
Zjr
VA
Non Fords
I got a cheap Amazon F150 and mounted it to the shroud. Easy as: trim one hole on mount, unscrew, place, re-screw.
Ford Maverick Front license plate 20240301_110337
Ford Maverick Front license plate 20240301_110302
Ford Maverick Front license plate 20240301_110314
Bwicka
Lakeside,ca.
Have yet to see any new corvettes since 2009 have them, any Ferrari’s or any other high end sports cars or many many ev brands!
