Four Drinks - Two Cupholders
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
Recently. My wife and I headed out in the Maverick to run errands. We decided to save time by running through a fast food drive-in for breakfast. In addition to our biscuits, we each ordered OJ and coffee. As we started to drive off, we realized we had four drinks and two available drink holders. We made do, eating and driving with one hand and holding a drink in the other. That led to my search for a better solution. I found an insert that fits just in front of the center console and provides two additional cupholders. In my case that would mean giving up two other added accessory trays and their storage options. Continuing my search, I came across Maxzina’s car door cupholders and ordered a pair.
Ford Maverick Four Drinks - Two Cupholders IMG_2439
Ford Maverick Four Drinks - Two Cupholders IMG_2442
Constructed of hard ABS plastic, the cupholders are held in place by a wedge that is captured between the side window and the window sill. In addition, a tab on the underside of the holder snaps into the door side just above the door handle. Fitted this way one can easily attach for use or remove them to store out of sight. When attached they provide a secure location for one’s coffee tumbler. Maxzina also provided a double-sided tape pad for those looking for a more permanent mount. My plan is to keep them under the front passenger seat until needed.
Cancunbadlands
Cancun
Cancun
Looks solid!
dmopro
Richardson, TX
Do they screw-up any added window tinting if you raise/lower the window? Just asking!
710-oil-614
Cal
2025 Hybrid AWD Lariat
can understand that you couldn't use the door pockets but in that situation I just reach into the back and pull the rear center console down and put my extra drinks there.
AbnRgr
AbnRgr
Athens, AL
Or you can add the Mabbet trash can to the center console FITS and you'll get 2 cup holders and a trash can!
I have it, but also have a net barrier between the front seats to keep our dogs in the rear, The net precludes us from reaching behind.
It appears you could slide it back a bit, and attach it just over the pivot point for the handle/lock lever.
That might be a good training item to learn NOT to press the lock lever when opening the door.
This may work
Granted they aren't going to hold super large cups because of the console. It gives you options.
Ford Maverick Four Drinks - Two Cupholders 20250813_121945
AbnRgr
AbnRgr
Athens, AL
I have only run the window up and down several times with no noticeable scratching, I can't speak over the long-term.
Cancunbadlands
Cancun
Cancun
I never had a drink in my car.
I did read some horror stories in the Bronco Sport forum... shifter dial damage 'cause coffee spills.
No warranty on it...
